Results 1 to 2 of 2
This is a discussion on '10~ LGT rear brakes on '08 WRX? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Since both cars have the same 190mm parking brake, I wonder if the vented 290x20mm rotor and the wider caliper ...
    Registered User fahr_side's Avatar
    Apr 2010
    Since both cars have the same 190mm parking brake, I wonder if the vented 290x20mm rotor and the wider caliper swap over.
    OTOH, since the LGT and 3.6R pads are taller, is the pad effective radius smaller than on the WRX, despite the rotor OD being the same? Perhaps the Legacy caliper has larger diameter pistons?
    Happiness isn't just around the corner, it is the corner.
    Apr 2010
    If anyone is interested, the 5th gen LGT rear caliper has a 40mm piston.
