11+ suspension mods
Results 1 to 2 of 2
This is a discussion on 11+ suspension mods within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Hello to all, i've been looking around several vendor pages and WRX tuners and it seems that not many have ...
    Sep 2012
    11+ suspension mods
    Hello to all, i've been looking around several vendor pages and WRX tuners and it seems that not many have yet released tested/proven lowering springs or full coilover suspensions. I know H&R and Eibach have their typical lowering springs but i wanted to see more of the non typical, RCE, Perrine... and what others are using to drop their 11+ WRX's. I beleive the suspension components aren't the same in these years as the previous '08-'10. I would really appreciate if anyone with after market suspension installed on their new WRX's could post some pics, reviews and specs(drop, rates..) I figured this would help a lot of us trying to see what fits and works. Thanks for your contributions.
    '12 WRX Sedan
    Sep 2012
    I'll start adding to my own thread.
    Brand: Eibach
    Return Policy: Standard Return Policy
    Mfgr. Warranty: Million Mile
    Adjustable: No
    Drop Height Front: 1.4 in (.8in - MY2011)
    Drop Height Rear: 1.2 In (.8in - MY2011)
    Drop Height Front Metric: 35mm
    Drop Height Rear Metric: 30mm
    Spring Rate Front: 114-268 lbs/in (progressive)
    Spring Rate Rear: 91-234 lbs/in (progressive)
    Brand: Epic Engineering
    Mfgr. Warranty: Lifetime
    Adjustable: No
    Drop Height Front: 1.2 in
    Drop Height Rear: 1.0 in
    Drop Height Front Metric: 30mm
    Drop Height Rear Metric: 25mm
    Includes Bump Stops: Rears Only
    Brand: Tein
    Series: Basic
    Mfgr. Warranty: 1 Year
    Adjustable : No
    Camber Adjustable : No
    Caster Adjustable : No
    Damper Type : Twin Tube
    Drop Height Front : 1.5in
    Drop Height Rear : 1.3in
    Drop Height Front Metric : 39mm
    Drop Height Rear Metric : 33mm
    Height Adjustable : Yes
    Independent Height Adjustable : No
    Spring Rate Front : 336lbs/in
    Spring Rate Rear : 280lbs/in
    Spring Rate Front Metric : 6Kg/mm
    Spring Rate Rear Metric : 5Kg/mm
    Top Hats Included : No
    Brand: Tanabe
    Series: GF
    Mfgr. Warranty: 3 Year
    Drop Height Hatch Front : .8in
    Drop Height Hatch Rear : .6in
    Drop Height Hatch Front Metric : 20mm
    Drop Height Hatch Rear Metric: 15mm
    Drop Height Sedan Front : .6in
    Drop Height Sedan Rear : .4in
    Drop Height Sedan Front Metric : 15mm
    Drop Height Sedan Rear Metric: 10mm
    Spring Rate Front : 252lbs/in
    Spring Rate Rear : 224lbs/in
    Spring Rate Front Metric : 4.5Kg/mm
    Spring Rate Rear Metric : 4.0Kg/mm
    rand: Racecomp Engineering
    Series: Regular Guy (Black)
    Mfgr. Warranty: Limited Lifetime Warranty
    Adjustable: No
    Drop Height Front: .7 in
    Drop Height Rear: .7 in
    Drop Height Front Metric: 19 mm
    Drop Height Rear Metric: 19 mm
    Includes Bump Stops: No
    Spring Rate Front: 275 lbs/in
    Spring Rate Rear: 250 lbs/in
    Spring Rate Front Metric: 4.9 kg/mm
    Spring Rate Rear Metric: 4.5 kg/mm
    Brand: Tein
    Series: SS-P
    Adjustable : Yes
    Camber Adjustable : Front Only
    Damping Adjust Type : 16 way
    Drop Height Front : 1.4in
    Drop Height Front Metric : 36mm
    Top Hats Included : Yes
    Fortune 500 Series Coilovers
    5 kg/mm = 279.987073 lbs/in
    6 kg/mm = 335.984488 lbs/in
    7 kg/mm = 391.981902 lbs/in
    8 kg/mm = 447.979317 lbs/in
    9 kg/mm = 503.976731 lbs/in
    10 kg/mm = 559.974146 lbs/in
    11 kg/mm = 615.971561 lbs/in
    12 kg/mm = 671.968975 lbs/in
    13 kg/mm = 727.966390 lbs/in
    '12 WRX Sedan
