Results 1 to 9 of 9
This is a discussion on 2013 wrx rims for winter within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; hello, does anyone know of a good winter rim and tire combo for my wrx? think it is 5 x ...
    Sep 2012
    hello,
    does anyone know of a good winter rim and tire combo for my wrx? think it is 5 x 114 55mmofffset stock... just got it and want get set for ohio winter in 3 months. looking for steel or? rims
    The WRX is not 5X114. Visit Tire Rack.
    KHP
    KHP is online now
    Registered User KHP's Avatar
    Oct 2010
    Reno, NV
    If you have a WRX (None STi) the hub lug pattern is 5x100 and wheel has an offset of 53mm.
    If you have WRX (STi) the hub lug pattern is 5x114 and wheel has an offset of 55mm. I believe no steel wheels will fit over the Brembos.
    +1 to above and check out Tire Rack website.
    2011 WRX Limited Spark Silver (5 Door)
    Sep 2012
    k non sti 5x100 53mm. thanks ill check t/r.
    Aug 2010
    Colorado
    I have a set of stock 2012 WRX wheels for sale. TPMS's will be included. Pictures available if interested.
    Sep 2012
    hello,
    what are you thinking on price, shipping? im in ohio zip 44134
    thanks
    Jan 2009
    Md
    why? Just get some conti DWS tires put on your stock wheels. Why waste all that money? Depending on where you live, you're going to drop 1000-1200 on wheels and tires and may not need them much. I have yet to be in a snow storm where DWS' would not very easily handle it.
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
    Jul 2010
    Cincinnati
    Quote Originally Posted by Methodical4u View Post
    I wouldnt say winter tires are a waste of money. I have my winter tires on from roughly thanksgiving until April. Summer compound tires are dangerous under 50 degrees. I spent $600 on a set of wheels and tires so I didn't have to re-mount and balance twice a year.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Jan 2009
    Md
    Quote Originally Posted by jd92677 View Post
    It depends on if you like a dedicated summer tire or not. If you do then you will have to switch or just not drive in the snow. If you don't mind sacrificing a little grip... the DWS' are the best A/S tire hands down.
