Results 1 to 15 of 30
This is a discussion on Lowering my 2012 WRX and keeping the OEM shocks - Suggestions? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Hey guys, As the title of the thread implies, I'm looking to lower my 2012 WRX Sedan on the OEM ...
    Registered User 2.5TurboWRX's Avatar
    Apr 2012
    Cincinnati, OH
    Hey guys,
    As the title of the thread implies, I'm looking to lower my 2012 WRX Sedan on the OEM shocks. I'm only looking for about an inch to an inch and a half drop and I'm not only doing it for looks as I would like to improve handling before I go stage 2. I'll probably throw a set of sway bars into the mix down the road but I'd like to do the spring first.
    Anyway, I've done some research and it looks like I have a handful of options available... From what I have gathered, I could install a set of RCE Black springs or the STI Pink springs without any negative effect to the OEM shocks, but I would be concerned these springs would not lower the car enough for my taste. I've seen anywhere from .75" to an 1" of lowering claimed using these springs. With that said, I've been looking at the H&R Sports as well as the Eibach Pro Kit as a possible alternative (both claim to lower the car 1.3-1.4 inches) but my concern would be how quickly the stock shocks would wear out using these springs?
    If anyone has any advice, experience or picutres of their 2011+ WRX on any of the above springs I would greatly appreciate the input.
    Thanks in advance.
    - Nick
    2012 WRB Impreza WRX Limited Sedan
    Not Asian Ying's Avatar
    Jul 2007
    Harrisburg-ish
    FWIW, all of the options you mentioned will shorten the life of your OEM dampers as they're valved for the OEM springs (under-damped I would say unfortunately). Generally, the lower you go, the faster they're going to wear.
    For a height reference, I have RCE blacks on the GTWorx Bilsteins, but I think the springs gave me a drop closer to 1" than .75". Any way you look at it, once you pick springs, you should probably start putting money aside for new dampers. There are 3 good options. The Koni Inserts, Feal Revalve, and GTWorx.
    2004 WRB WRX Cobb Stage II - Sold...2004 PSM STi Cobb Stage II - Sold...2011 WRB WRX Torqued Performance Stage I - Daily Driven
    My current average MPG
    ClubWRX.net Vendor KronosPerformance's Avatar
    Nov 2005
    Bordentown, NJ
    No one can honestly give you an answer on how long they will last for...could be a year....could be 2 years...couple be 2 months. Your giving your shocks a better chance however by staying on the Pro Kit or H&R Springs.
    We supply them both in case you need a price:
    Eibach Pro-Kit for 08+ Subarua WRX 4 & 5 Door 2.5L Turbo [7721.140] - $280.00 : Kronos Performance, Fueling the Car Lover Within
    H&R 08-up Subaru Impreza Sedan/ Hatchback Sport Spring H&R 08-Up Subaru [54460] - $286.00 : Kronos Performance, Fueling the Car Lover Within
    ClubWRX.net's #1 Vendor! - www.kronosperformance.com - Call/Text 732-742-8837 |
    AIM Screenname - KronosParts | GoogleTalk - sales@kronosperformance.com | Military Discount
    [/SIZE]
    USE COUPON CODE FIRST5%OFF to receive a discount of your first order
    Kronos has Special Pricings on Process West & Agency Power!
    CONTACT US DIRECTLY FOR SPECIALS AND PROMOTIONS
    Mt. Laurel, NJ
    Lowering your car will greatly reduce the life of the OEM struts. When will they go? No telling...but a lot faster than with the stock springs.
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    I seem to remember someone post that he blew the OEM struts on aftermarket springs after just 4k miles.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Apr 2012
    Cincinnati, OH
    From what I have read the RCE Black Springs and the STI Pink Springs are both designed to be used in conjunction with the OEM shocks. That would lead me to believe that they would not cause them to wear out any faster than the stock springs would.
    Either way though, I'm not all that concerned with wearing out the OEM shocks, I figure since they only have 1400 miles on them now I might as well get my money's worth out of them before I replace them with expensive aftermarket shocks.
    Does anyone have pictures of a 2011+ WRX lowered on springs?
    - Nick
    Jul 2007
    Harrisburg-ish
    RCE Blacks
    Measurement from peak of fender to center of wheel:
    13.5" F / 14" R when I measured months ago.
    The rear is a little higher (10mm) because I had to move the cir clip on the bilsteins up to the top setting to clear my KB endlinks...long story. I think it's settled a little since those pictures were taken. The front is perfect though IMO. Keep in mind I'm going for performance more than looks so I didn't want to drop the car out of it's sweet spot.
    Cheeky Bastage! spirited09wrx's Avatar
    Oct 2009
    Dirty Jerz
    Quote Originally Posted by 2.5TurboWRX View Post
    wont you not be getting your monies worth if you blow them anytime before a few years?
    Zach
    Teh Intern @ WTF Tuning, LLC
    2009 WRB Subaru Wrx Sedan: WTF Tuning Stg2
    Stink eye Mob #287
    N.E.R.D. #43252003274489856000 (the total number of configurations of the Rubik cube)
    "It's not turbo-lag, it's foreplay"
    Apr 2012
    Cincinnati, OH
    That's better in my mind them taking them out and letting them sit in my basement collecting dust... It's not like they are worth anything used.
    And thanks Ying for the pictures!
    After seeing how the front of your car looks, I really might consider the RCE Blacks. I just so happen to live a few blocks away from TIC and I believe they sell them and can install them for me. I was afraid they wouldn't be low enough, but your wheel gap looks to be about half of what my stock wheel gap is, which would be perfect.
    - Nick
    Jul 2007
    Harrisburg-ish
    Yeah the front is definitely close to an inch from stock. If I had my way, the rear would be there as well. Keep in mind that Feal can re-valve your OEM dampers to work precisely with the RCE Blacks which should increase their life expectancy. That way they'll be collecting dust on the road instead of your basement.
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    I've had my prokit for about 53,000 miles. I'm just now getting to the point where they will most likely need to be replaced
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Apr 2012
    Cincinnati, OH
    Quote Originally Posted by wrxtreme06 View Post
    On the OEM shocks???
    - Nick
    May 2007
    orlando flawduh
    Yup. The prokit is not very aggressive and I've had great results with them
    desiree
    06 impreza wrx tr
    facebook
    Mt. Laurel, NJ
    You also drive in the extremely flat un-winterized roads of Southern Florida...roads up in the North are MUCH more harsh on suspensions.
    Jul 2010
    Cincinnati
    Here's my '11 on eibach pros, stock struts. I got them cheap on ebay so I figured I'd try them out
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
