Camber Bolt Question
Results 1 to 12 of 12
This is a discussion on Camber Bolt Question within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I don't know if I'm posting this in the right section, but I was wondering if stock camber bolts can ...
    Jan 2011
    Aurora, CO
    I don't know if I'm posting this in the right section, but I was wondering if stock camber bolts can be used in conjunction with aftermarket ones. ex: Eibach Camber Bolts.
    I have a 09 WRX.
    Suspension: BC BR Coilovers
    Looking to add: (So I can change camber)
    - Eibach Camber Bolts
    - Lower control arms (Cusco, GTSpec, or Agency Power)
    Camber plates?
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
    Jan 2011
    Aurora, CO
    I have camber plates in the front already, but my stock camber bolts are maxed out. Just wondering if I can use Eibach Camber bolts in conjunction with the stock ones.
  5. #4
            MainFrame's Avatar
    Austin, TX
    You can, but generally the idea is that you replace the stock bolts with the aftermarket ones. If you need even more camber (I don't see why you would) you could use both the stock and aftermarket adjustment bolts. You could put the aftermarket bolt in the bottom hole and move the factory one to the top hole, then you could get even more adjustment by placing the lobes on the bolts in an opposing fashion.
  6. #5
    Jan 2005
    Eh, whaaaaa?
    The camber plates are there for a reason. Max out the stock bolts to where they are both even, then use the camber plates to adjust to the desired camber setting. In the rear you will need the eibach kit unless you buy the rear camber plates as well.
    Cody
  7. #6
    Jan 2011
    Aurora, CO
    yeah i need more camber as stock is maxed out completely.
    Quote Originally Posted by Anub1s View Post
    08+ require LCA to adjust camber in the rears.
    my fronts are placed for more positive camber so my stock bolts ended up maxing out
  8. #7
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by krntehknik303 View Post
    Right you are, sorry about that, apparently didn't notice the year of the vehicle in the OP. My bad.
    As for the front, I'm confused, you have the camber plates set for positive camber? Or am I misunderstanding the post?
    Cody
  9. #8
    Jan 2011
    Aurora, CO
    Sorry about that I meant to say positive caster. My tuner/mechanic set it up so that I would be running more positive caster. So when I went an got an alignment, my stock camber bolts were maxed out negative. I forget by how much though. That's why I was wondering if I can use two camber bolts for negative camber.
    Sent from my SGH-T959 using Tapatalk 2
  10. #9
    Registered User Acrdys's Avatar
    Jun 2007
    Lemore
    yep. get a camber bolt made for the bottom strut hole. Make each bolt oppose each other.
    Camber bolts - 14mm
    Hawk-Eye Alliance#8089
    MODS LIST
  11. #10
    Registered User mmiller2002's Avatar
    Nov 2007
    Ft. Worth, TX
    These were $16 a couple years ago.
    Ingalls Engineering 81260 - Ingalls Engineering Fastcam Camber Adjusting Bolts - Overview - SummitRacing.com
    I had them in the bottom front holes for a while, but decided I didn't like the risk of them loosening. I got Whiteling Com-C top mounts for the extra biit of neg. camber.
    '02 WRX Wagon
    RCE wagon springs
    Koni inserts
    Com-C Top Mounts
    Kartboy Endlinks
    Sedan rear swaybar
    Others little stuff
  12. #11
    Jun 2007
    Lemore
    Com-C's are awsome. Here's a vid of my install http://youtu.be/gPJsqk--e6Q
    MODS LIST
  13. #12
    Jan 2011
    Aurora, CO
    Thanks for the suggestions
