It sounds like a bad tire. Check and make sure all the tires are seated on the beads. make sure the wheels fit properly on the hub. Make the the wheels are mounted flat and tight on the hub. try rotating front to back. a bad tire in the rear cant really make it pull like that. why did u change from the factory tires?
LinkBack URL
About LinkBacks
