The OFFICIAL 2011/12 WRX wheel/tire thread - Page 6
Page 6 of 24 FirstFirst 12345678910111213141516 ... LastLast
Results 76 to 90 of 359
This is a discussion on The OFFICIAL 2011/12 WRX wheel/tire thread within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; This question is for Torque (as I see you are the Yoda here). I'm running on my 2013 hatch: -XXR ...
  1. #76
    Registered User 98sob's Avatar
    Dec 2011
    Pennsylvania
    -XXR 527 18x8.75 +35 w/ 245/40/18 tires
    -Stock Suspension
    I'm rubbing in the rear with no one in the car. At first my fenders were taking huge chucks out of my side wall. So I rolled them mildly and now they only slightly rub now (barely on spirited driving)
    I feel this is crazy at stock height. What are my options? Should I buy stiffer springs? I want to keep my height especially after this mess but my issue lies with suspension travel. My ride seems incredibly bouncy with 4k on my odometer.
    Any of your input would be great!
  3. #77
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Quote Originally Posted by 98sob View Post
    -Stock Suspension
    Yea that is a weird size/offset. It's pushed out there different. What you could do is take it to an alignment shop and get them to give you a custom alignment. Custom meaning to your specs and not necessarily within spec. A rear -1.5 of camber should get you to not rub. Otherwise you will need to lower the car to achieve that camber, but lowering is not needed, you can get a camber kit and get the car to a nice alignment spec. How much did you roll your rears?
    Lead Wrench @ WTF Tuning, LLC
  4. #78
    Dec 2011
    Pennsylvania
    I was thinking of using negative camber...just wasn't too into the idea.
    How does lowering the car achieve the camber I would need? I don't understand? The springs I would get would be Eibach Pro Kit on stock struts. I was concerned I would get the stiffer ride I wanted but eventually the blown struts would create the opposite effect.
    I only rolled the fenders so that they are facing maybe a 20-30 degree angle upwards.
    Thanks for the reply!
  6. #79
    Dec 2004
    Medford, Oregon
    Lowering a car creates negative camber that most of the time needs to be corrected. Sometimes it gives to much negative camber and installing camber bolts allows an alignment shop to adjust the car back within spec.
    Eibach pro kits are designed for use with stock components but eventually your shocks need replaced which would then only make the car handle that much better over stock.
    I mentioned lowering because the 3G body styles are expensive to get a rear camber kit for.
  7. #80
    Dec 2011
    Pennsylvania
    I agree...I'd much rather lower it than buy a camber kit for it.
    So moving forward I should get the Eibach Pro Kit? That should relieve this issue you think?
    Thanks!
  8. #81
    Dec 2004
    Medford, Oregon
    Getting some camber will help the tire not rub anymore. Post some pics. You can always roll the rear fenders a little more too
  9. #82
    Registered User aladeen's Avatar
    Jan 2013
    Denver, CO
    Quote Originally Posted by WrxPower View Post
    Thanks. Like Torque has said. I had to roll my rear fenders only. I'm on Eibach springs so a roll was needed. I have no rubbing at all even with two adults sitting in the back while driving.
    I've been eyeballing the same wheels for a while now, and I'm undecided between 8.5" or 9.5". Glad to hear that you only had to roll the rear, because I'm on the same springs. Have you noticed any decrease in steering response/ turn-in capability with the wider wheels? They look awesome on your car by the way!
    -Alex- 2012 WRX 5dr / World Rally Blue / Stage 3+Stig
    I sell Subarus in the Denver area!
  10. #83
    Registered User Dzanga's Avatar
    Oct 2011
    phx
    My 2013 on 18x9.5 +35 rota torques with tanabe lowering springs Fender rolling in the rear.
    2012 Wrx SWP Hatch-Traded
    2013 Limited ISM Hatch -Current
  11. #84
    Dec 2011
    Pennsylvania
    Quote Originally Posted by Dzanga View Post
    which tanabe spring?
  12. #85
    Oct 2011
    phx
    Df210 I think is the model number or df240
  13. #86
    Dec 2011
    Pennsylvania
    Yeah I see Rally Sport Direct has them under Df210. Awesome drop and no rubbing during spirited turning?
  14. #87
    Oct 2011
    phx
    None at all you have to roll the rear pretty good though haha and I had to grind the plastic on the bumper a little I will take a picture when I get home
  15. #88
    Dec 2004
    Medford, Oregon
    My white car ran a 265/35/18 on a 18x9.5 rota DPT with an et of 35. Rear fender roll was required, not a pull of any kind.
  16. #89
    Dec 2011
    Pennsylvania
    Here is my set up..
    18x8.75 + 35 XXR 527
    245/40/18 Pirelli
    Stock height with a very mild roll.
    I am going to roll the rears all the way up and go with tanabe df210
    Hopefully it works? What do you guys think?
  17. #90
    Oct 2011
    phx
    Here is my set up..
    245/40/18 Pirelli
    You probably won't have to roll all the way In the rear. I would roll a little at a time and see how it goes. If you roll too much it will pop out and make a gap
    Sent from my iPhone using Tapatalk 2
