The OFFICIAL 2011/12 WRX wheel/tire thread - Page 17
Page 17 of 24 FirstFirst ... 789101112131415161718192021222324 LastLast
Results 241 to 255 of 359
This is a discussion on The OFFICIAL 2011/12 WRX wheel/tire thread within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; NICE, this is exactly what I'm doing as soon as winter breaks. I figured this would hold me over until ...
  1. #241
    Dec 2013
    Northern Ohio
    NICE, this is exactly what I'm doing as soon as winter breaks. I figured this would hold me over until I fork the coin over for some new wheels. what lug nuts are you using? I planned on switching to red also and those look nice.
    Quote Originally Posted by gelmanskiii18 View Post
    Plast dipped for almost a year now!
  3. #242
    Registered User gelmanskiii18's Avatar
    Sep 2012
    Foxfield, CO
    Thanks. Like you, I'm saving some dough too for a nice 18 incher. But for now, stocks will work fine. This is the second winter with the plasti dip, power wash them, and still holding ok. Got the lug nuts from Sickspeed, very light.
    Quote Originally Posted by ears2305 View Post
  4. #243
    Registered User Brazilnut's Avatar
    Jul 2013
    Colorado
    Final thoughts on my future summer set-up before I pull the trigger??
    Wheels: Enkei Raijin 18 x 9.5 et+45
    Tires: 255/35/18
    Suspension: Currently on Tein coilovers, f/r sways as well
    Thanks in advance for your advice!
  6. #244
    Registered User ThatBroBill's Avatar
    Jun 2013
    Long Valley, NJ
    Yes those wheels are fugly if ur going to do a 18x9.5 do something that has a nice concave front or stick to a 17x9
    Love bill
  7. #245
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by Brazilnut View Post
    Tires: 255/35/18
    I thought about the Raijin's when I was originally wheel shopping too, but ultimately went with something different (just personal preference). I went back and fourth about going 9.5 but was swayed against going over 9 inches wide (partly due to performance, and partly because of the tire cost)...The 9 inch wheel is actually much wider than I thought. I would go with 265's if you are going to 9.5 inch wheels. I have 255's on the 9 inch wide wheels that I have and they fit perfect. Good offset you have though, that will give you a much more flush look.
  8. #246
    Registered User WrxPower's Avatar
    Mar 2012
    Florida
    These wheels do have a nice concave to it. How do I know you say? I have these wheels!!
    Is there a certain reason why you don't want a 265 tires? 255 would be the lowest I would go with a 9.5 in wheel.also your going to have to roll the rear fenders.
  9. #247
    Jun 2013
    Long Valley, NJ
    Quote Originally Posted by WrxPower View Post
    not with a +45, 35 yes
    It's very very minimal with a 45 offset and if you're going to run a bigger wheel you're slightly putting form over function so why stop there? Run a more aggressive offset as well you have to roll your rear fenders anyways
  10. #248
    Mar 2012
    Florida
    I don't understand how the offset affects concave.
  11. #249
    Nov 2013
    It's where the hubcap is so they could either be concave or deepdished. I believe.
  12. #250
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    Do you understand what Offset means? Quick picture that will illustrate how it would affect the concave of the wheel.
    http://www.tirerack.com/wheels/tech/...jsp?techid=101
  13. #251
    Mar 2012
    Florida
    What I know about offset is the lower the number the more the wheel/tire stick out of fender. The higher the offset the more the wheel/tire are closer to fender. Theses wheels raijin are a one piece wheel so how can a lower offset affect the concave? I can't remember if enkei even makes a lower offset.
  14. #252
    Jun 2013
    Long Valley, NJ
    Because the distance from the outside of the lip to center of the wheel is further away so the concave on the front of the wheel is deeper.
    They make a 35 as well as a 38 i believe they may be special orders but i have seen them on cars.
    This may help you understand the concept better
    https://www.youtube.com/watch?v=qwiqAr2bI-I
  15. #253
    Jul 2013
    Colorado
    Ok, thanks for the input gang!
  16. #254
    Registered User LENSPEC's Avatar
    Dec 2013
    Long Island, New York
    The degree of concavity of some wheels is affected by the offset.
    Some wheels, however, this does not apply to. For example:
    With RPF1's, it is the width of the wheel that determines whether or not it is concave or convex.
    So with RPF1's, the 7", 7.5", 8", and 8.5" widths have a convex face regardless of offset.
    And the 9", 9.5", 10" widths, etc. all have a concave face regardless of offset.
    Above 9" on these, they all have the same lip and just the hub depth is changed to determine the offset.
  17. #255
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Tires: 255/35/18
    This is the same setup I am planning to get!...... eventually
    Quote Originally Posted by ThatBroBill View Post
    I have done a pretty fair amount of research on these wheels, and the only offset that Enkei offers in this wheel size (bolt pattern 5x100 wheel size 18" x 9.5") is +45. If you want any offset lower you have to go all the way down to an 8 inch wheel width. At that size they give you the option of +45 or +35. HERE is the link to the size chart for the Raijin.
    EDIT: with a +45 offset you still have a nice little bit of concavity to the appearance.
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
