The OFFICIAL 2011/12 WRX wheel/tire thread - Page 16
Page 16 of 24 FirstFirst ... 6789101112131415161718192021222324 LastLast
Results 226 to 240 of 359
This is a discussion on The OFFICIAL 2011/12 WRX wheel/tire thread within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Originally Posted by KHP Ok just a different perspective. Instead of just assuming that .2 difference in height difference is ...
  1. #226
    Oct 2013
    Quote Originally Posted by KHP View Post
    Ok just a different perspective. Instead of just assuming that .2 difference in height difference is "nothing". Lets actually do some calculations.
    Cool....did you remember if you saw the difference in differential revolutions as the diameter increases by .1 at 65 mph?
    I'll be sure to post back if I see any negative affects over the years of ownership.
    I always wondered how camber effects the diameter of your wheel/tire. What variables would i use to figure that out?
  3. #227
    KHP
    KHP is offline
    Registered User KHP's Avatar
    Oct 2010
    Reno, NV
    Quote Originally Posted by boostem View Post
    It should be about less than half that at .1" height/diameter so
    With your current setup your diff never rests as it constantly absorbs some energy at city speeds to quite substantial energy once you hop on highways.
    Regarding negative effects you may or may not feel any negative effects during normal driving. Viscous couplers usually fail gracefully (you end up with a completely open center diff). I've seen some diffs fail in bad way where they completely lock up and you end up with a binding drivetrain whenever you turn.
    Negative effects of open center diffs is quite hard to feel until you end up in some low traction situations. The car may feel like it lost its' dynamic handling and it will not be able to transfer power well between front and rear axles.
    Regarding camber I would like to believe that Subaru ran the rear tires at a lower pressure to help with the more pronounced positive camber and also lighter weight on the rear end from the factory. Factory pressure is 32R 33F.
    2011 WRX Limited Spark Silver (5 Door)
  4. #228
    May 2013
    Colo Springs, CO
    i have a sizing question. i have an '11 wrx sedan on stock suspension. looking at getting 18x8.5 Rota G-Force (5x100/e48/56.1). What is the meatiest tire i could get away with? without rolling or lowering
  6. #229
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    offset of 48 is the problem with the above statement
    Lead Wrench @ WTF Tuning, LLC
  7. #230
    Dec 2004
    Medford, Oregon
    Also an 18x9 with an offset of +38 is NOT the same as an 18x10 +38 there is an inch difference in the wheel the offset is different like I stated above.
  8. #231
    May 2013
    Colo Springs, CO
    what offset and tire size would i need to run with the 18x8.5 to avoid problems?
  9. #232
    Dec 2004
    Medford, Oregon
    you arent going to run into problems with an 18x8.5 et 48 its just the look that isnt the greatest
    this is 18x8 et 48 with 235/35/18 see how far into the fender they sit? Needs to be about a 40 or 42 on an 18x8 or 8.5
  10. #233
    May 2013
    Colo Springs, CO
    oh yeah that does look pretty bad. didnt realize 48 were set in so far...
  11. #234
    Dec 2004
    Medford, Oregon
ID:	129873Click image for larger version.
    This is an 18x9.5 with a 38 offset and 275/35/18 tires
    This is an 18x9.5 with a 35 offset and 265/35/18 tires
  12. #235
    May 2013
    Colo Springs, CO
    the 18x9.5 with 35 looks great. is that on stock suspension as well?
  13. #236
    Dec 2004
    Medford, Oregon
    No it with the konis and 08 tein s techs so its lowered like an inch maybe
  14. #237
    May 2013
    middletown ny
    18x9.5 et 40 on GR wrx tires 255/35/18 how much rolling is required on coilovers
  15. #238
    iH4
    iH4 is offline
    Registered User iH4's Avatar
    Apr 2013
    the OC
    I'm getting close to making my decision... its between 18x9.5 +43 or 18x9 +38 on 255's.
    My question is: Anyone running 9.5" front have rubbing issues on hard turns. I'm a very spirited driver and would like to run the wider (concave look) but concerned about rubbing inside wheel fender. I'm not slamming the car, it'll probably have a finger gap. I'm on coilovers running stiff Eibach ERS springs. Thanks!
    Time for AWD fun! CBS 2013 WRX Sedan - SoCal - OC
  16. #239
    Dec 2013
    Northern Ohio
    Information overload going on here!! Just to clarify, 18x9.5 et38 with a 255/35 or a 265/35 going on a stock 2011 WRX with no intentions of lowering, will work? New sways may be as far as I intend to go for now. Now being the next 3-4 years.
  17. #240
    Registered User gelmanskiii18's Avatar
    Sep 2012
    Foxfield, CO
    Stock 2013's WRX
    Plasti dipped for almost a year now!
