Results 1 to 2 of 2
This is a discussion on Any experience with d-spec series? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I've got a blown rear driver side strut, so im getting both rears replaced. I read a bit about the ...
    Registered User rednisson350z's Avatar
    Sep 2010
    Warren, MAine
    I've got a blown rear driver side strut, so im getting both rears replaced. I read a bit about the d-spec series and sound pretty good for what I've read. Anyone have any experience with these? And is it fine to run these in the rear while having stock front struts? (i plan on getting fronts when the money comes around in a couple months) and do i have to do anything with the springs with these or are the stock ones all set? thanks
    Jul 2001
    Plains of Eastern Montana
    moved to the wrong forum- will be moved to the correct shortly
    never have run D-Specs, but you're correct the reputation is favorable
    if it's only short term, running just the rear will be fine- not long term though
