Results 1 to 6 of 6
This is a discussion on 02 WRX with STi Suspension-wheel alignment..? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I just recently had the 06 STi suspension (struts, springs, top hats) put on my 02 wrx. I was wondering ...
    Registered User wrx0131's Avatar
    Jul 2007
    Yonkers, NY
    I just recently had the 06 STi suspension (struts, springs, top hats) put on my 02 wrx. I was wondering if the wheel alignment would be the 06 STi specs or the 02 WRX specs.
    Thanks for any answers.
    Bugeye Mafia #213
    Kevin
    2002 Midnight Black Pearl WRX (Traded In!)
    2012 Ice Silver Metallic STi Sedan
    Jan 2005
    Eh, whaaaaa?
    They're whatever specs you want them to be. I don't trust ANY factory specs, personally.
    Cody
    Apr 2007
    8000' up in Colorado
    Since the main components of the suspension tying everything to the car are the same, I'd err towards the WRX settings. But you really need to decide for yourself on this one. You can set it up however you like. There's no right or wrong answer here.
    Scott
    Jul 2007
    Yonkers, NY
    Thanks guys. I just don't want my tires to wear quicker. I already lost one tire due to my previous struts being bent, causing too much negative camber.
    Bugeye Mafia #213
    Kevin
    When you see a car that's worn its tyres evenly across the surface on all fours, you're sometimes seeing a car that won't turn. IMO responsive steering and max traction when cornering imply at least somewhat increased wear. How much depends on you. Look at the factory specs and see if it's something that interests you. Definitely go for 0 (zero) toe and then decide how much camber you like. Without toe, camber alone tends to be quite forgiving, so even at over 1' negative you may find you are not seeing dramatically accelerated wear. Meanwhile, the car will allow you to change directions relatively well too. Compromises, find one you can accept.
    May 2005
    Phillytown, PA
    F Camber: -2.0-1.5 deg.
    R Camber: -1.5-1.0 deg.
    Toe: Zero
