Uhhh... there are rust holes in my subframe!
Page 1 of 3 123 LastLast
Results 1 to 15 of 38
This is a discussion on Uhhh... there are rust holes in my subframe! within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; While putting my winter wheels on and doing my stabilizer links today, I noticed that my 2002 WRX has a ...
    Aug 2009
    Massillon, OH
    While putting my winter wheels on and doing my stabilizer links today, I noticed that my 2002 WRX has a horribly corroded subframe. Mostly behind the front wheels, I can actually punch through the metal with my finger (only did it once... don't want to lose anymore structure!). I'm pretty unhappy about this issue... I've NEVER seen a problem like this on a car, even after working at a Honda dealership as a service advisor in NE Ohio.
    Now, I'm no idiot and know this isn't good. So:
    1. How concerned should I be?
    2. Is this common?
    3. Should I talk to a Subaru rep?
    4. Any idea how much $$ damage I'm looking at?
    5. Are there any aftermarket solutions?
    6. How difficult is this? Is it a possible DIY project?
    Thanks!
    Hi, I'm Mike and I'm a recovering Euro Snob.
    Registered User Poohbear's Avatar
    Mar 2009
    Ohio
    I would call subaru. I know they have a 5 or 6 year rust protection but your an 02.. none the less they may help... Who knows, could have been a bad batch of wrx's that left the plant with poor undercoating and your in some kind of recall or some junk.
    If not, and subaru wont help; being your sub frame I would say whats your safety worth? I know your "no idiot" but are you sure its a structural part of the car? I mean even though you picked away at the rust and dont want to pick any more away I doubt it was doing any structural duties with that kind of cancer anyhow.
    I know sub frame braces are made for autos like mustangs, but I dont think they make them for wrx's; and even then you need solid metal to bolt or weld to anyway, not rust.
    also keep in mind that there is more rust then just what you see... I dont wanna make it sound worse, but it probably is... If you see a rust hole the interior of that part of the frame (at the least) is pretty badly rusted.
    Iv seen this happen with older Mercedes and they end up crushing like accordions in a collision.
    But really if its not bad you can eliminate the rusted parts and weld in steel... but it wont be as sound or as safe as before the rust.
    Pricey? depends on the extent. I would say if it is bad then your probably better off buying an 02 or similar with no motor or tranny etc etc etc and swapping everything over. But im anal retentive about safety...
    EDIT- Also being in ohio we have to deal with that nasty salt on salt off in the winter. After all you know as well as I do, we get an ice storm and salt is placed. Then being crazy ohio weather its like 50 degrees the next day with nothing but salt water on the ground... And thats all bad for the under body of our cars. So Im going to say that it was the local weather and salt thats causing the issue.
    Your vehicle is an extension of your skill as a driver, not a substitute for it.
    Stink-Eye Mob Member #21
    08+ Gauge install DIY
    Turn off your seat belt chime
    Oct 2005
    Late Devonian
    I haven't heard of any rust-through issues yet but they will probably start to rear their head more too soon.
    Is it the front or the rear? The front one you just bolt off and then back on. The rear you have to drop the diff (not too bad) and then there are suspension attachments (i.e. you need an alignment when your done). There are various aftermarket options. I would do the group N rear differential bushings if you have to do the rear.
    Mar 2009
    Ohio
    ^^ didnt know they were bolt ons.. I figured we were more a true unibody construction, affixed to the car.
    Registered User Sarra's Avatar
    Aug 2008
    Dreadford, OR
    Quote Originally Posted by Poohbear View Post
    Being a 'sub-frame', they quite simply just do that, bolt on.
    Not sure why they did that in the rear, but it's probably a good idea, seeing how yours is rusting away.
    The subframes can move while you drive, a few companies make subframe locks that will do just that, lock the subframe in place.
    The subframe mounting bolts being loose will throw your alignment all to hell, specifically rear camber, and the front cradle being loose can throw camber and caster out.
    Aug 2009
    Massillon, OH
    It is the front subframe and yes, it appears to be a bolt-on.
    After fighting the corroded stabilizer links and the associate hardware, I'm not about to tackle the subframe myself... when you're an amateur mechanic with just a few simple tools, it makes for an interesting experience. haha
    I'm taking it to the stealership today. I'd like to go through them, I think. She needs an oil change anyways, and she hasn't been to a dealership in years, I believe... the PO did all his own maintenance.
    I've been seeing parts go for $150 used... not cool.
    Aug 2009
    Massillon, OH
    I spoke to Subaru Corporate and they didn't seem interested in any kind of coverage. They agreed that they'd never heard of it in a WRX... same with the dealership.
    It's sounding like I'm going to source a used part and do it myself.
    I really expected more from a Subaru...
    Registered User indytruckboy's Avatar
    Oct 2008
    Reading, PA
    Quote Originally Posted by 22WRBWRX View Post
    What do you expect from a 7-8 year old car?! How many miles are on it?
    I work on vehicles that make 650hp and 2400ft/lbs.
    Aug 2009
    Massillon, OH
    Quote Originally Posted by indytruckboy View Post
    Considering all the time I've spent around cars after working at a dealership and NEVER having seen this on any car that ever came through the shop, I'd say it's unexpected.
    I've talked to quite a few technicians who agree.. this kind of thing IS rare.
    The car has 98k miles on it.
    The reason why I talked to Subuar Corporate is because even the local Subaru dealer was shocked and thought it should be covered by some goodwill warranty. They had never seen anything like it.
    So, to answer your question, I expect more from a 7-8 year old car.
    Jun 2003
    Western NY
    My wife's 02 WRX just got hit with the exact same thing. We took it in for a new radiator and they found enough rust in the front subframe to keep it from passing inspection next month.
    Oct 2005
    Late Devonian
    Quote Originally Posted by improvius View Post
    The subframe is not weight bearing. Just unbolt and replace it with a used one from the junk yard. Also, you can throw in an ALK or a better bushing while your in there (makes a noticeable difference for sure).
    Jun 2003
    Western NY
    Thanks for the tip. Is this part going to be identical with one from a TS or Outback Sport?
    Oct 2005
    Late Devonian
    I don't know but expect it might.
    Aug 2010
    Vermont
    rusted subframe 02 wrx
    I just got the same diagnoses... for a rare problem it seems to be hitting a lot of 02 WRXs... thanks for all the tips, guess I'm off to the junkyard..
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    I hate to say it..... but honestly.... I'd sell the car.
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
    1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
    2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
    WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
    WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
    Co-Founder/retired Admin-www.slcsubaru.com
