Results 1 to 12 of 12
This is a discussion on Stabalizer link? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; This looks like the stabilizer link is broke? Can you get that pressed back in? And i'm at work so ...
    Registered User FaaipDeOiad's Avatar
    Apr 2009
    Springfield
    Stabalizer link?
    This looks like the stabilizer link is broke? Can you get that pressed back in? And i'm at work so how safe is it to drive?
    Apr 2009
    Springfield
    Oh, and I also noticed while under the car that my right inner CV joint is leaking. Looked into it and saw that a new axle is the cheapest and safest way to go. For those who did it, where did you buy it? I checked Advance real quick and its 80 bucks. Also if I were to do it my self, other than a impact or breaker to get the axle nut off, what tool do i need to get the snap ring off? We use small ones at work, but i'm sure I will need a bigger tool for this one.
    Registered User kalidas's Avatar
    Jan 2009
    Tucson, AZ
    I would just buy a new set of aftermarket links.
    I dislike doing CV boots. They are one of my least favorite things to repair on a vehicle. I have yet to do one on a Subi, but on all other vehicles it was worth it to buy the whole half-shaft then just swap it out and return for your core charge. The first few times I did them, I would just replace the boot after cleaning and inspecting everything. It's much better to just buy the shaft, saves time in the long run.
    Apr 2009
    Springfield
    Yea I am going to replace the axle, for the price it makes sense. I just dont have the tools to do it, but some of my boys do so I should be ok. But i checked on some after market bar links, and 115 bucks is way to much, when the OEM is only 30.
    Dec 2003
    Dallas, TX / Sterling, VA
    I would really recommend aftermarket (specifically Kartboy) endlinks.
    Apr 2009
    Springfield
    I would like to upgrade whenever I replace something, but ive got an axle and a clutch to replace so its gonna have to be OEM for now.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by FaaipDeOiad View Post
    End links are cheap. But a good quality one... They may even be cheaper than the OEM ones.
    The only type that I would recommend is a "Spherical Ball" style bushing. Such as the Perrin.
    Oct 2012
    My stabalizer link just snapped on my 02 wrx while reversing 40 min from home. When i reverse the wheel turns completly. I can drive foward but only tried going 15 mph to a friends to park. Is it safe for me to drive home? Can i just not reverse or do i have a more serious problem the. Just the stabalizer link Click image for larger version.
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    You can drive home, just be very careful, as your car will handle much differently. If you have basic tools available, remove the broken endlink to keep it from banging into things.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
    Oct 2012
    Was able to get the car jacked up. Closer looked revealed this Click image for larger version.
ID:	108689 completely rusted through... Fff now what? Leaving the car in place for now. HELP!
    Registered User WRidesX's Avatar
    Oct 2011
    CO
    Quote Originally Posted by Danie24932 View Post
    This makes me nervous, I have an 02 as well. Perhaps looking into replacing these things should be next on my list.
    '02 WRX Bugeye; Midnight Blue / Black Pearl
    Oct 2012
    Quote Originally Posted by WRidesX View Post
    Yeah supposedly there was a recall on the lower control arm so im hopeing to get it replaced by subaru. Gonna call the dealership first thing monday, ill let you know how it turns out.
    Subaru Announce Recall of Impreza (02-07) Forrester (03-08) & Saab 9-x - DirtyImpreza Forums.
