gauging interest wagon (and sedan :)) front spherical links
Page 1 of 5 12345 LastLast
Results 1 to 15 of 75
This is a discussion on gauging interest wagon (and sedan :)) front spherical links within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I know some of you posted in the previous thread http://www.clubwrx.net/forums/suspen...end-links.html wanted to start a new thread, this will be ...
    Jul 2001
    Plains of Eastern Montana
    I know some of you posted in the previous thread gauging interest in front spherical sway end links
    wanted to start a new thread, this will be for front wagon links
    stainless rod ends (teflon liners), hardware/spacers and rubber covers-
    pic of the links from the previous run
    price should be under $100 if I can get a confirmed 12 sets
    thanks
    Mike
    1.) wrx wagone
    2.) Hold_Fast
    3.) kalidas (09)
    4.) mycologist
    5.) Lipster
    6.) Nectar_Balen
    7.) ODJ
    8.) sfflyfish
    9.) ILikeToGoFast
    10.) your name here
    May 2005
    Phillytown, PA
    First.
    Jul 2001
    that's one
    Registered User chimchim's Avatar
    May 2005
    SF Bay Area , CA
    I assume you have to reuse your stock bolts/nuts...?
    Registered User Hold_Fast's Avatar
    Mar 2008
    Philly Burbs
    Second!
    ~Stan
    '04 WRB WRX Wagon (Build) - Hard Parked, AutoX Toy
    '08 WRX ~ Daily Beaten ~ '86 BMW 325es ~ "The Chump"
    "I was raised knowing there is a replacement for displacement, it's called engineering."
    Jul 2001
    well this is a little frustrating this is the original thread that was lost, now the other one is now lost
    we had four or five guys signed up, hopefully they'll pipe in on the new thread
    new hardware will be included, so no you won't have to re-use your stock hardware (but you could )
    Hold_Fast got you added
    Dec 2003
    Dallas, TX / Sterling, VA
    Is there really a huge difference between adjustable and solid end links? I need new rear endlinks.
    Apr 2004
    Southeastern PA
    Mods & Pics
    Jul 2001
    that's the "original" original , this one is take 2, but it disappeared so I started a take 3, which now has subsequently disappeared
    oh well- if the new server works better than the old I can live w/ a lost thread
    not a huge difference, but some-depends a lot on the bushing used in the solid one- spherical has almost no deflection- solid ones have some (to a lot depending on the bushing)
    the adjustability can come in handy at times as well
    Registered User kalidas's Avatar
    Jan 2009
    Tucson, AZ
    So are these the same as the ones that you made before? I know there was a discussion in the original thread about doing them for the older wagons, and I don't know if there would be a difference between those and the ones you made for the 09's.
    Basically it boils down to this: If they fit the 09 hatch, I am in for a set.
    Jul 2001
    the 09 (and 08) will require some different hardware/spacers, but the same rod ends, but it should be doable
    there were a couple of names that were on the thread that disappeared that I don't have listed now, hopefully they'll chime back in
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    So, nothing in the works for the sedan ??
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Oct 2005
    Late Devonian
    Glad I found this again - please put me down for some wagon end links.
    Thanks
    May 2005
    Phillytown, PA
    Quote Originally Posted by pzr2874 View Post
    You guys had your shot.
    Jul 2001
    mycologist- added you (again )
    pzr- the 08/09 links I believe are the same, so I can do sedan ones as well- as mentioned above the hardware/spacers are different, the rod ends are the same
    it would be helpful if you could take a measurement for me though just to be double sure- if you could measure the distance from the center of the upper bolt to the center on the lower bolt (might have to take off the link to get a good measurement)
