Repair estimate? Knowledge would be nice!
Results 1 to 8 of 8
This is a discussion on Repair estimate? Knowledge would be nice! within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I hit a curb last night going about 25 into a corner. Wet ground plus bald tires didn't work too ...
    Registered User nicknoble's Avatar
    Mar 2009
    Everett, WA
    I hit a curb last night going about 25 into a corner. Wet ground plus bald tires didn't work too well...
    I hit the curb on the front passenger side wheel pretty hard, and the wheel assembly is now riding on the back of the wheelwell. I don't know much about suspensions and how they work, and it doesn't look like I bent the frame, so can anyone give me a ROUGH estimate for damage repairs? I'm thinking LCA? axle? What controls where the wheel sits?
    I live in WA and normally repairs are about $70 an hour.
    Dec 2003
    Dallas, TX / Sterling, VA
    Wonderful pictures you posted.
    Mar 2009
    Everett, WA
    It happened last night and I didn't have a camera with flash to take any
    I'll head over and take some today, luckily a buddy lived nearby so I could store it overnight.
    Mar 2009
    Everett, WA
    Just got home with some pics, keep in mind I do not know much about what I am doing, so your help is greatly appreciated.
    Photobucket
    Photobucket
    Mar 2009
    Everett, WA
    bump for wondering how bad off i am
    Apr 2009
    You have a bent control arm, and broken end-link at the least. You may have also bent the front control arm bushing mount, tie-rod, and tie-rod end.
    control arm, end-links, and tie-rod end can be installed yourself (assuming you have a shop manual, tools, and some wrench-time).
    Replacing a bent tie-rod is a bit more complex, and if you bent the front bushing mount for the control arm do yourself a favor and call a frame shop.
    You should also have an alighnment to ensure you havent bent either of the front struts.
    A cousin of mine wreched my 03 sedan but insterting it into the rear fenderwell of an Explorer. My wheel was a little further into the firewall than yours was, and was blown apart, the control arm folded in half.
    I replaced all four struts and springs with Tokico Dspec kit.
    Installed Kartboy end-link front and rear. Both control arms replaced with STi control arms. Of course a few additional upgrades while i happened to be working on the car, i couldn't resist, but i still have the car on stands because the front CA mount is bent and after several attempts to straighten it myself I'm getting close to giving up and sending to a frame/body shop or replacing the cross-member completely.
    Anyway, hopefully you've gotten it repaired by now, if not, hope this helps.
    Apr 2007
    8000' up in Colorado
    You're going to need a new wheel, axle, and a few other suspension components depending on exactly what broke. Are you also going to have the front fender fixed (straighten & paint)?
    I'd say 10 hours labor on the repair plus another $1500 in parts. But that's really hard to say without getting a lot better look at it.
    The fender repair is about $1200-1500 but that depends a lot on the shop.
    Scott
    Registered User eg6ajk's Avatar
    Feb 2008
    Cool
    Check out car-parts and Millenium Auto(y2kparts)for some used parts prices, there is also classifieds here and on Nasoic.
    Roughly you're looking @
    LCA ($50-$100),
    endlink $20-30,
    tie rod $30-50,
    ball joint $15-40,
    strut ($50-150) and
    possibly the subframe $100-400 (you can upgrade to 05+ w/ quicker rack and all).
    Best case total =~$250, worst case scenario about $600 in parts, the rest will be labour which would probably be in $200-600 range.
