part #'s of interest for 08/09 WRX guys - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
This is a discussion on part #'s of interest for 08/09 WRX guys within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; you could, but for the $ your not gaining much w/ the 09 dampers- it was first thought that w/ ...
    Jul 2001
    Plains of Eastern Montana
    you could, but for the $ your not gaining much w/ the 09 dampers- it was first thought that w/ the decent increase in spring rates w/ the 09 we'd see decent increases in damping- RCE had the 09 dampers dyno'd and saw very little increase in damping
    if you find a set used and cheap, might be worth it- otherwise I'd opt for Koni's or Bilsteins
    Registered User spt wrx 2k8's Avatar
    Dec 2008
    Queens, NY
    Since I wasn't apart of that group deal over @ NASIOC in the begining - those gtworx/bilsteins are 1k... and as for the Koni inserts - i dunno if i trust inserts in the same stock tubing...
    Why has no one made a decent strut/shock combo for the 08+, its been 2 yrs already...
    I <3 SASHA.M
    Mar 2009
    [QUOTE=spt wrx 2k8;2652440]
    Why has no one made a decent strut/shock combo for the 08+, its been 2 yrs already...[/QUOTE]
    I thought the same thing today. Looked around and theres nothin.
  6. #19
    Dec 2008
    Queens, NY
    [QUOTE=ScorpionWins;2652492]
    Quote Originally Posted by spt wrx 2k8 View Post
    LOL, love the username! I dunno about paying Koni all that money for inserts, but its definitely a cheaper option vs the gtworx bilsteins.
    I may just bite the bullet and for over 1k to gtworx...i wanna do a complete suspension for spring 2011 - tires, stuts/shocks, sways, tophats, bushings, etc.. and the stupid strut/shocks are holding me back.
    I <3 SASHA.M
  7. #20
    Jul 2001
    Bilsteins will be worth the $ and Koni's are worth the time, both good options- there won't be any better options than those
    no one else holds a candle to Koni or Bilstein
  8. #21
    Dec 2008
    Queens, NY
    Doh! Well I guess I have to see which one pairs up with the STi pinks..
    I <3 SASHA.M
  9. #22
    Sep 2010
    Does anyone know why the 09 shocks/springs don't show up on opposedforces.com?
  10. #23
    Jan 2015
    Quote Originally Posted by butlejas View Post
    Hey I'm sure many people have seen this by now, but the spec C rear swaybar from the 2010 sti SE is a 19 mm. Should fit as well... 2010 part # 20451FG020 (and its CHEAPER than the 18mm! WTF?)
    Also, since the new 2011 WRX will be given a wider track to match that of an sti... is it possible that the front dampers from an sti would fit?? I know that they couldn't before because of the narrower track... any insight would be appreciated.
    "here's the 19mm bushings (order two) 20464FG020 "
    So, it IS confirmed, that the same year STI's rear sways will fit the WRX SEDANS? And, the 19mm bushings, are they designed to have the same wall thickness, thus requiring a bigger clamp? Or do they keep the same bushings for the thinner bars just hollow out the inside diameter of the hole allowing for the same bar clamps. Anyone have this fully confirmed? I heard that the STI's use bigger rear bar clamps.
    '09 silver WRX sedan.
  11. #24
    Sep 2010
    The STi bars fit the WRX hatch, don't see why the sedan would be different. The 19mm bushings don't require a larger clamp.
  12. #25
    Jan 2015
    I was told the hatch has all SORTS of different suspension parts.
  13. #26
    Sep 2010
    Just checked the hatch and sedan have the same part number for the rear sway bar.
