gauging interest in front spherical sway end links - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 75
This is a discussion on gauging interest in front spherical sway end links within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; loving your avatar I may be able to do rears- I have a set of lateral links still and some ...
    Jul 2001
    Plains of Eastern Montana
    loving your avatar
    I may be able to do rears- I have a set of lateral links still and some oe rear links so I could probably do a mock up (the 08/09 rear links are completely different)
    Registered User Garrian_Guitars's Avatar
    Jan 2008
    Dayton, OH
    Lookin' good, Mike. I'll baby mine along a little longer and hold out for ya. If you need an engineer/mechanic to run a double check for fit and function I'd be happy to offer any assistance I can provide on an 04 WRX w/ Cobb sways. You've certainly gotten a great response already, we're looking forward to it!
    Thanks again for offering it up
    Jul 2001
    looks like about six sets should do it?
    should clarify these will be front links for the sedan (wagon are trickier)
    I'll be ordering end of this week, early next week
  6. #19
    Registered User Ric WRX's Avatar
    Aug 2008
    Hey BigSky make sure you include me. I have installed STI SPT Pink springs already. They help a lot.
    Thanks
    Richard
    2008 WRX Premium-Sedan, WRB, Invidia DP, SPT CBE, VF-52, TGV Deletes, Walbro F/P, Stg 2 CAMTuned, Pink springs, Whiteline Sways, Brembos F/R, RPF1, Star Specs, Pioneer/Alpine/JL, Kartboy SS/Bushings, Leather Seats and JPM Coachworks Boots, DAMD flat bottom steering wheel, Grimspeed M/C brace,TRS HID Retrofit.
  7. #20
    Registered User penderperson's Avatar
    Jul 2007
    pm on the way
    05' Subie WRX
  8. #21
    Apr 2004
    Southeastern PA
    Mods & Pics
  9. #22
    Jul 2001
    got all the bits ordered (five sets worth)
    everything is a little on the pricey side, but the quality will be top notch
    stainless hardware right down to the washers and spacers, should be pretty nice
    found these online- good quality I'm sure, but look at the price
    Draco 04-07 Subaru WRX STi Adjustable End Links - Front
  10. #23
    Registered User wrxmuch?'s Avatar
    May 2008
    Nashville
    WTB: Rears for an 04 wrx.
    Cobb Accessport v1 stage 2 93 map, Nitto Invo Tires, Sti Front and Perrin Rear Sways, Rota Torque Wheels, APS Exhaust 3.5" turbo back. Catless TurboXS Up pipe, Goodridge Stainless Steel Brake lines, Hawk HPS Brake Pads, Paranoid Fabrications Cowl Braces, Group-N Tophats, Group-N Trans and Engine Mount, Tokico Dspec w/ Rce Black springs
  11. #24
    Jul 2001
    if there is some demand- I might be able to make up some rears- we'll see how it goes w/ the fronts
  12. #25
    Jul 2001
    finally got all the bits- that's the good news, bad news is they are not going to be under $100
    I have $496 into five sets, that's $96 a set. I'm having to put a quite a bit of time into assembly (I have to cut spacers and de-burr them, also the rubber boots are a little challenging to get on )
    I figure about $10 for shipping. Figuring $10 for my time and $4 for paypal fees- so $120 total.
    These are nice pieces though. Quality rod ends, stainless hardware and full rubber boots- should make for a top-notch sway link set.
    I'll pm folks w/ payment info.
    Mike
  13. #26
    Jan 2008
    Dayton, OH
    Great!
    Looks like you've put some serious work into those. That's quite a boot! Again, I can't thank you enough for making these available to your fellow clubwrx members Paypal sent.
    How was testing and mock-up? Uneventful I assume?
  14. #27
    Jul 2001
    yeah a little more pita than I anticipated, but that's usually the case anyways
    no hardcore testing but I'm confident these will easily do the trick
    got you paypal thanks- I'll have the links out early next week w/ tracking numbers
  15. #28
    Jul 2001
    two sets went out today- pm's sent
    I'm include some general install instructions- if you need more detailed ones just holler. If I was a graphic artist I'd do a fancy drawing (if anyone would like to do a fancy drawing please feel free )
    the links are assembled, the links consist basically of male and female rod end- the male rod end is mated to the sway bar, the female end to the control arm. there is a thin jam nut that can be loosened to adjust the height if needed (I'd suggest not lengthening it too much as it weakens the link- the length should be pretty close and small adjustment- shorter or longer are fine)
    you'll notice the way they are assembled that the bolt at top points inward and at the bottom the bolt points inward, both top and bottom there is a flat washer and a nylock nut that goes on the opposite side of the sway bar and control arm tab. Torque both these nuts to 35 ft lbs.
    Also when installing use ramps, you want the suspension loaded.
  16. #29
    Jul 2001
    here is rough (that's very rough ) drawing
    so rough that it's deleted, look at the much nicer one below
  17. #30
    Jan 2008
    Dayton, OH
    Installation Diagram
    I got the shipping notification, I'll let you know when they're in. I drew up a little assembly diagram based on your sketch.
