Man, that is a good read. I guess these tire companies and distributors will do whatever it takes to make a few extra bucks. Bastards...
This is a discussion on A heads up about the tires on your car within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; i forget the exact numbers, but its something like within 4 years its lost 50% . i know at the ...
i forget the exact numbers, but its something like within 4 years its lost 50% . i know at the shop i worked at we had to get apprval to work on anything 5+ years old and 10+ we were not supposed to touch. rarely followed this. it depends on more than just age. mostly location and if they were kept outside (sunlight takes the oils right out of a tire hence the cracking and stuff you'll see in a sidewall). its scarier when you see codes that are from the 90's or before the DOT numbers were in their current format.
"90 miles an hour through trees sideways is pretty damn scary" ~Ken Block
This is a good story, but I have to disagree with the arbitrary number of 6 years. I've raced in tires older than that with never a problem. I bought a used car with tires so bad they were cracking on the side walls. I didn't drive it on the freeway with them, but I drove it around town from shop to shop to get it repaired on them with no problems and then I bought new tires for it. These things looked frankenstein, but they never failed.
Also, do you have any idea how much tire prices will rise if they have to pull all those tires over 6 years old? Can you imagine selling your car, but there is a law that says you can't sell a car with tires over 6 years old? I can.
Also, I have to ask, how many of these failures are caused by low tire pressure? I know of many tires that have failed due to low tire pressure, and they have the new monitoring systems mandated now for all new cars and I bought one off Amazon to put in my sti, so I really think the problem is low tire pressure and not just because the tire is old.
Also, how many of those failed tires are from unknown brands or imported tires?
With all that said, in the story, he indicated he bought them 5 years before and they were 4 years old at the time. 9 year old tires. Okay, but only one blew out. The other 3 were fine. In the video you can see none showed any signs of failure. So if 6 years is the limit, 3 other tires worked fine. Is it not more likely that that one tire was underinflated?
beware the full size spare! Most look new and havent seen much action esp on your moms '92 camry
most tire warranties are for 5-6 years after installation..not the DOT born on date.
because of centrifugal force tires in motion want to peel and come apart. if a tire tread peels off the tire carcass then it would not be caused by under inflation. Under inflation/over loading failure would be more overheating and sidewall damage i think..tho an over loaded/under inflated 14 yr old tire would prolly be disaster
another possible scenario that a tread would peel off would be an incorrectly repaired tire.
if you get a tire repaired by patch water might get in the heart of the tire from the outside. The steel belt could rust and rot the tire from the inside causing the peeling effect.
if you get a tire repaired by plug you have about a 50/50 chance of going back to get it repaired again assuming you make it there without under inflation damage.
whats teh solution you ask? plug AND patch your tires but finding a place that does that might be difficult. I know costco does it for sure
:edit: but costco only repairs their own tires
Last edited by sangwooT; 10-22-2008 at 09:16 AM. Reason: but costco only repairs their own tires
i'm running BFGoodrich traction T/As on stock rims on stock rims and they are awesome for where i live. i need to get some good summer tires for some 18s i'm getting. water evacuation is a must but tear up dry pavement. don't wanna spend more than $180 (unless Goodyear Eagle F1 DGwhich i've been drooling over). have been looking at the Kuhmo MX. any suggestions?
im checking my tire date on my 08 wrx tom
thx for the video!
I checked my summer Hankook RS2s laying in the garage the other day and couldn't find any number resembling what they described. The only thing I know is I bought them in summer '06.
2005 World Rally Blue WRX Sportwagon
Biatch totalled my 2002 WRB WRX Sportwagon
I miss my bugeye.
Image is nothing, performance is everything. All your rice be ownz by us.
If you're not going to spend your money on women or alcohol, you might as well spend it on cars.
the link isnt loading for me, can some one give me a quick run through of this?
bugeye maffia member #304 l http://www.flickr.com/photos/joe_fonseca/
Great info![]()
It's surprising that this is still known by very few people. IIRC, that ABC story is at least a year old, but this should've been known for a long time.
It's about the shelf life of tires. Even if you buy them brand new, that only means that they've never been used, but they could be years old already. They only have a finite life span and can fail catastrophically if they're merely too old and haven't been used much. In the ABC story, 2 guys died in a minivan where tire failure was the only cause of the accident.
