Tire size help? 225's on Stock 06 17x7.5
Results 1 to 14 of 14
This is a discussion on Tire size help? 225's on Stock 06 17x7.5 within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; i was woundering if i could fit 225's on my 06 wrx with stock 17x7.5 rims. any help? thanks...
    Registered User 06skeeterwrx's Avatar
    Feb 2008
    Nor Cal
    "POWER IS NOTHING WITHOUT CONTROL"
    - PIRELLI TIRES
    Apr 2007
    8000' up in Colorado
    Yes, they'll fit, but I wouldn't recommend it. I wouldn't go wider than a 215 on a 7.5 rim. 205 is even better. At 225, your sidewalls are going to be at a serious angle which is going to screw up your cornering abilities.
    Why do you want to go to 225 width?
    Scott
    Oct 2005
    Ocean Grove, NJ
    ahem
    From my mod list:
    Suspension:
    Tein SuperSport Coilovers
    Tein EDFC (love this thing)
    Cusco 3way adjustable rear sway bar
    Helix Rear Endlinks (spherical/ball mount)
    Moog Extreme Camber Bolts
    Falken Ziex512(205/50r16) on stock 16's
    Potenza RE-01R(225/50r16) on Bronze Volk TE37 16x7.5
    You just need stock 16" wheels.
    Jul 2004
    Seattle, WA
    I had a set of "Rota Grid" 17x7.5 on my car with Michelin Pilot Sport PS2 225 r45's they fit perfectly strait up and down, great tires too
    Apr 2004
    Southeastern PA
    What do you base this on? Have a look at tire size charts from the tire makers themselves. They show minimum and maximum rim widths for a given tire size.
    225/45 will fit nicely on a 17 x 7.5" rim. I ran 225s on a 17 x 7" rim for three autox seasons. 225 is the largest a 7" rim can do.
    Edit: My current tire specs from Dunlop: Dunlop Tires - Find The Right Tire - Tire Specifications
    Mods & Pics
    May 2005
    Phillytown, PA
    wat?
    I have a 225 on my 17x7 rims, it's fine. I've also seen a 235/40/17 on a 17x7.5, that was also fine. Granted there are variations in tire widths between manufacturers, but a 225/45 on a 17x7 isn't a problem.
    BTW, the stock 06 wheels are a 17x7.
    Apr 2007
    I noticed he didn't post the right size and I was talking about a 7" rim. As 04.SPT.WRX said, a 225 is pushing it on the stock rims. If you want to run a 225 for every day street use, you should step up to a 7.5" rim.
    Scott
    Apr 2004
    Southeastern PA
    I did? It is the minimum recommended size - this is not pushing it.
    I ran 225s on a 17" x 7" for nearly four years. Those same 7" rims will now be my winter rims with 225s on them. 225/45/17 comes very close (.4%) to the OEM 205/55/16 diameter. Have a look: Tire size calculator
    Wider is better, but a 7" rim can safely and efficiently support a 225/45/17. Check the specs from the tire makers.
    Mods & Pics
    Feb 2008
    Nor Cal
    thanks for all da info i just went along with 215 and omg i didnt realize how much new tires make a car feel so great lol
    - PIRELLI TIRES
    Apr 2004
    Southeastern PA
    Tires will make or break the overall feel of a car.
    Including the OEM RE92s I have had four different tires on my WRX since 2004. Each was unique in the way they made the WRX behave. The current Dunlops are hands down the best yet.
    Mods & Pics
    Registered User Web Foot STi's Avatar
    Jun 2003
    Portland, OR
    Um, I picked up my car used. It had 17 X 7.5" rims with RE-070 225/45/17 tyres. Used as the OD had 7 miles on it...
    Cones don't count at Hillclimbs.
    Registered User wrx02blk's Avatar
    Jul 2007
    Minnesota
    I'm running 225/45/17 just fine on my 17x7 Motegi's on my WRX as a daily driver.
    My '03 Jetta GLI came with 17x7 rims with 225/45/17 tires from the factory.
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    It's not impossible. I used to bullseye womp-rats with my T16 and they're no larger than 225/45/17...
    My Pirelli's (225/45/17) fit perfectly flush up-n-down on my stock 17x7 rims.
    Next time I'm going to 235/45/17 on my 17x8 Ozs.
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Registered User Slide's Avatar
    Oct 2005
    Quote Originally Posted by 04.SPT.WRX View Post
    What is it about your tires that you like? I recall you said you have tried several sets now. I'm in the IMMEDIATE market for new tires, but am only on stock rims currently.
    I'm on my blizzaks still and a tire thats meant to be soft in the winter is SUPER soft in the summer...I need to get off these things before they are ruined.
    I looked at 4 models of dunlops all in 225/45/17
    Dunlop
    Direzza Sport Z1 Star
    Dunlop
    SP Sport Maxx
    Dunlop
    SP Sport Maxx (new ones of the same model apparently)
    Dunlop
    SP Sport Maxx A
    Other than the Direzzas being Extreme summer tires and having a more gummy appearance and tread style...and likely a much faster wear time what is great about these tires?
