TiC Tok Suspension Kit - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
This is a discussion on TiC Tok Suspension Kit within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Big Sky WRX your rear top choice is dictated by the spring you run- if you run ...
    Registered User c2bcoolwrx's Avatar
    Mar 2008
    SFLA
    your rear top choice is dictated by the spring you run- if you run a 02/03 style spring then you must run a 02/03 style top, if you run a 04+ style spring then you must run a 04+ style top.
    a 04+ top won't fit onto a 02/03 style spring and vice versa
    IC. Thanks for the help.
    Registered User Trueno Azul's Avatar
    May 2008
    Springfield PA (Delaware County)
    COBB Stage 2 Suspension Kit
    I'm trying to install Cobb's stage 2 suspension kit.
    But th emechanic told me that for an 06 WRX it takes 6 hours to just put the springs!? Total of $700.
    He said putting front and rear sway bars would be even more.
    How can this be? He said the springs needed to be put in a compression machine for proper fitting. From what I've seen on YouTube it seems fairly easy an the guy in the video did it in 7mins for an EVO 8. I figured the strut type cant be that different.
    Could somebody please tell me how much it costs for a suspension kit to install, and what is the deal with the springs?
    Thank you!
    May 2005
    Phillytown, PA
    A competent mechanic can easily have springs done in 2 hours. You should be looking at ~$250 with an alignment.
  6. #19
    Registered User 05Wrex's Avatar
    In the middle of a corn field somewhere in Illinois
    Quote Originally Posted by wrx wagone View Post
    +1 Shouldn't be a difficult job. I just rented some spring compressors from autozone.
    OBP 2005 Wrx - Big 16g
