ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Suspension & Wheels
Suspension & Wheels Subframes, A-arms, uprights, shocks, struts, coilovers, swaybars, hubs, brakes, wheels, and tires! Sponsored by The Tire Rack
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 05-31-2008, 06:05 PM   #1 (permalink)
jkcrewsn's Avatar
Looking for help tuning suspension
Hello all, as you can see this is my first post. I purchased a 2002 wrx wagon and have been in the process of modifying the suspension. So far I have installed: Cusco f/r strut bars, Eibach Pro-Kit Springs (stock struts), Rallitek f/r sway bars (rear set to middle hole, Whiteline end links in front), and Whiteline Adj, Lateral Links.
I bought the car about three months ago and haven't driven it much since I was out of town for the last two. I was only able to add the strut tower bars the last time I was home, but was able to purchase and have waiting the sways, springs and lateral links. I had a shop install the springs Thurs. put the sways on myself Thurs/Fri and had a tire shop install the links and do an alignment today (Sat). The reason I give the time line is to underscore the fact I haven't had a lot of time driving the thing with small changes, I pretty much threw everything at it and don't know what really did what.
The question (or issue) I have came after the lateral links were installed, and the alignment was done. It seems to have the opposite effect of what I was expecting. The rear of the car seems to shift more laterally when I go into a turn. And most curiously, if I am driving straight at around 30 - 35 and flick the wheel one way or another its almost as though the car wants to "rebound" (go past center) back. It is like the car wants to rotate, but I can't seem to get the rear loose. And overstuffing a corner introduces understeer (cheap tires perhaps). The alignment numbers are as follows: Camber Front: L -1.5, R -1.2 Rear: L -1.5, R -1.7. Toe is Front: L 0.04 R 0.05 Rear: L 0.00 R 0.02 and Caster is L 3.7 and R 3.6
Now, the car takes any corner I can chuck at it, but its that initial "uh-oh" that happens when the rear feels like it going to take a walk that worries me.
My thinking is that perhaps I have stiffened the rear of the car to such a degree that it always wants to overdrive the front. I was going to reset the rear bar to its softest position and try that. Do I need to get an ALK kit and Whiteline ball joints to make the front stiffer, or is it something in the alignment settings that is making it feel like it wants to rotate? Perhaps the initial softness of the Eibach springs aren't up to the task of working with the lateral links and stiffer swaybar?
As you can see, I have thought about this but am pretty much fishing for answers. If anyone has any suggestions I would certainly like to hear them.
By the way, I'm running some Maxxis 215/45/17's the guy I bought it from had on there.
Jeff
jkcrewsn is offline   Reply With Quote
Old 05-31-2008, 06:45 PM   #2 (permalink)
Timdog1650's Avatar
Send a message via AIM to Timdog1650
Right rear camber is 1.7 or -1.7?
Not sure, but might you be referring to tramlining? Where the car sort of wants to steer itself back and forth along the road because of the tracks worn into the lane of traffic by heavy vehicles...
Timdog1650 is offline   Reply With Quote
Old 05-31-2008, 07:08 PM   #3 (permalink)
jkcrewsn's Avatar
Nope, not following grooves (tramlining) and all cambers are in negative (sorry, edited that on the op). And just to clarify, the tires are sticking to the pavement fine, its just that the body shifts over (but almost not a "roll" just a "shift"). It's an odd thing, hard to explain I guess.
Old 05-31-2008, 08:57 PM   #4 (permalink)
Timdog1650's Avatar
Sorry man, outside my expertise...I'll let someone who knows more about suspension chime in.
Old 05-31-2008, 09:18 PM   #5 (permalink)
STI_KLR's Avatar
Send a message via AIM to STI_KLR
Contact BigSkyWRX, he's basically the suspension god.
__________________
Rogan: Live simply, love generously, care deeply, speak kindly.
>>Mods List <<
Bugeye Mafia #196
Scoobies for Autism Meet: 2009 Edition
STI_KLR is online now   Reply With Quote
Old 06-01-2008, 08:07 PM   #6 (permalink)
Moderator
Big Sky WRX's Avatar
well your alignment #'s look pretty good, I don't see anything out of the ordinary there
if the getting if the rear is too loose, going to a softer sway bar setting should help
the Impreza takes a fair amount of driving to get the idiosyncrasies down- it has to be driven a little differently then most cars. The term slow in/fast out really applies to the Impreza.
It would be a lot easier if I could drive the car. Might be worth finding someone knowledgeable to take a spin in it, it's possible that something wasn't installed properly
this may sound silly but check the torque on your lug nuts, it's very common for them to loosen up after being removed- that will make your car feel like crap (shifty) for sure
__________________
Big Sky WRX is offline   Reply With Quote
Old 06-01-2008, 08:51 PM   #7 (permalink)
Timdog1650's Avatar
Quote:
80-85ftlbs, right?
Old 06-01-2008, 11:42 PM   #8 (permalink)
wrxwalsh's Avatar
your bushings may be worn out and the stiffer suspension may be accentuating that movement. if everything on your car react to a certain force, and the bushings are softer, the bushings are going to squeeze and squish around casuing the motion you are talking about... the MR2 has the same issue. put poly bushings in... night and day difference
Matt
__________________
UTA FSAE FTW!!!!
Cars
1993 MR2 Turbo- lots of mods 300rwhp
2004 WRX - down pipe, 18's, more to come...
wrxwalsh is offline   Reply With Quote
Old 06-02-2008, 06:45 AM   #9 (permalink)
Moderator
Quote:
Originally Posted by Timdog1650 View Post
80-85ftlbs, right?
the FSM says 69 ft lbs, I have better luck w/ 76 ft lbs
about bushings- the WL lateral links come w/ poly bushings throughout, the only suspension bushings left in the rear are the trailing links- they generally influence more fore/aft movement, but do have some effect on lateral movement as well
__________________
Old 06-04-2008, 06:46 AM   #10 (permalink)
jkcrewsn's Avatar
Thanks for all the input. The lug nuts are tight (checked that out quick), so maybe its just getting used to the way the suspension is working now with all the different parts. I have never had a suspension set up like this, and it certainly handles well. I am looking forward to getting the front end upgraded as well. Thanks again for all the replies.
Jeff
By the way, does anyone else have a hard time getting on this site? I haven't been able to get here for the last few days.
Old 06-04-2008, 07:07 AM   #11 (permalink)
Moderator
the server has been messing up for me as well
__________________
Old 06-04-2008, 07:36 AM   #12 (permalink)
jkcrewsn's Avatar
Well at least it isn't just me.
I was looking at the pre alignment numbers and noticed that prior to the alignment I was running (in the rear) Left Toe: -1.96 and Right Toe: -1.37. The toe is now L: 0.00 and R: +0.02, so I suppose that could account for some of the difference in feel as well.
Old 06-04-2008, 11:09 AM   #13 (permalink)
Moderator
if those were your pre toe numbers- wow! I can't imagine tires lasting at all w/ those #'s, not the least the extreme dartiness you would have felt
__________________
Old 06-04-2008, 11:10 AM   #14 (permalink)
Moderator
are you sure those are your pre toe #'s ? they are extremely high
__________________
Old 06-04-2008, 03:13 PM   #15 (permalink)
The sensation that you describe could definitely be caused by something being loose in the rear suspension. I would put the car on jackstands and check everything. Yank,shake,twist. Tire/wheel assemblies,strut/spring assemblies,bars,etc. Make sure that all of the nuts and bolts are tight,including the top strut nuts. Look for any sign of tear or distortion in bushings.
Redneck Slim is offline   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
