Results 1 to 15 of 21
This is a discussion on WRX 04 lower spring suggestion within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Just got the WRX 04 and I love it. I plan to drop its ride height, and looking at this ...
    Mar 2008
    EIBACH Sportline lower spring with F/R 1.6"/1.4". (Part number 4.1477).
    So I quickly run to my baby and estimate her current height. It's about F/R 3.25"/2.00".
    3.25 - 1.6 = 1.65 Front
    2.00 - 1.4 = .6" Rear
    So after doing some calculation, i got F/R 1.65"/ .6".
    Also im looking at another set that give me F/R 1.45"/ .8".
    So which one of these two you guys think is the most suit for my car? Remember it's just estimate number, but i doubt it's close enough.
    Registered User wrxwalsh's Avatar
    Sep 2007
    Spring/ Arlington
    where are you measuring those heights from? BTW, WRXs dont like to be lowered very much... the camber curves blow... so you may want to rethink the lowering springs... maybe a set of JDM Pinks or STi Takeoffs.
    Matt
    UTA FSAE FTW!!!!
    Cars
    1993 MR2 Turbo- SOLD
    2004 WRX - SOLD
    2008 Civic Si
    Mar 2008
    I measure from the fender to wheel surface. Anyway, JDM Pinks and STi Takeoffs are spring or what?
    Sep 2007
    Spring/ Arlington
    Quote Originally Posted by grenadeking View Post
    yes they are pretty common on the market... the STi takeoffs can probably be had from a person with an STi that has done springs or coilovers for 100 bucks or less. the JDM Pinks come in a couple of different rates
    http://z1auto.com/prodmore.asp?model...ing&prodid=234
    /\ theres a link that better describes the rates
    Matt
    UTA FSAE FTW!!!!
    Cars
    2004 WRX - SOLD
    2008 Civic Si
    Sep 2007
    Spring/ Arlington
    oh i dont know how much you have or want to spend but but if you want some height adjustibility but you dont want to break the bank you may way to look into Grond Control Coilovers. its just a threaded peice that sits on your stock spring perch and Grond Control allows you pick the springs rates you want. pair them with a good performance shock and youve got youself a coilover set-up on par with something a quite bit more expensive
    Matt
    UTA FSAE FTW!!!!
    Cars
    2004 WRX - SOLD
    2008 Civic Si
    Mar 2008
    What's the difference JDM pink( or STI takeoff) and EIBACH Sportline lower spring?
    Sep 2007
    Spring/ Arlington
    the amount of lowering... for the most part the springs rates are close to the same... however, the biggest difference is how much you lower it... the lower the shocks the less time your shocks will last... not to mention the lower your springs are the more time you spend in positive camber... which is very bad for handling unless you run an absurd amount static camber. which will kill your tires. but the again im sure you could put the springs on and just go for the look.. but i guess that depends on your priorities with the car. if you want ultimate handling then i would say to look elseware, but if you want the look then go for it...
    Matt
    UTA FSAE FTW!!!!
    Cars
    2004 WRX - SOLD
    2008 Civic Si
    Mar 2008
    Im not into ultimate handling though. So I decide to go with the EIBACH one. Im not sure whether I measure the correct location or not but here's the pics. Pls correct me if that's not the way to measure ride height
    The right Front wheel with red arrow.
    Sep 2007
    Spring/ Arlington
    there isnt really a right or wrong way as long as it works for you... generally we measure form the top of the fenderwell to the center of the wheel so i just thought that your measurement was a little short i was just curious...hope the sportlines work out great for you! post up pics when you can!
    Matt
    UTA FSAE FTW!!!!
    Cars
    2004 WRX - SOLD
    2008 Civic Si
    Mar 2008
    SO my measurement was short lolYeah, the Sportline gonna be fine I think. Thank you for the help Matt.
    Jul 2001
    Plains of Eastern Montana
    ride height should be measured from the center of the hub to the wheel arch- measuring to the top of the tire is relatively meaningless- folks run all kinds of different tire combos that vary in height- it's all apples and oranges w/ that scenario. Measured from the hub makes it all relative regardless of the tire/wheel combo
    the Eibach spring rates are softer than the WRX pinks or STi takeoffs, in addition to lowering more
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    you shoulve gone with the prokit.. eibach themselves say that if you plan on getting the sportline, you need to replace your stock struts or they'll blow out due to the drop being so agressive. just throwing that out there.
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Mar 2008
    So the Prokit is ready to install without replace the strut right? It would be nice to see u guys post up your car with lower spring and how much did u drop it.
    May 2007
    orlando flawduh
    yup the prokit will work with your stock struts so you dont have to worry about anything. they ride great too.. but the drop isnt that extreme:
    before:
    after:
    5 minuts after install:
    a month+ after they settled in:
    desiree
    06 impreza wrx tr
    facebook
    Mar 2008
    look good for me. How many inches did u drop it for front and rear.
