Page 4 of 8 FirstFirst 12345678 LastLast
Results 46 to 60 of 112
This is a discussion on Poor mans gold wheels (painting) within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Yulri;2238977[IMG http://img378.imageshack.us/img378/7159/dsc01821zo9.jpg[/IMG] these are how mine turned out... the pics make them look a bit more bronze ...
  1. #46
    Registered User joesubaru7's Avatar
    Jun 2006
    D-VILLE, PA
    Quote Originally Posted by Yulri;2238977[IMG
    these are how mine turned out... the pics make them look a bit more bronze than they are... I originally didnt like them that much since i thought they were too dark but now they have grown on me. I used all rustoleam stuff. Two coats of grey primer, two coats of gold rush metal paint, and 4 coats of clear coat on the back of the wheels with 5 coats on the front.
    So how many cans of each did you use? How are they holding up?
    2006 WRX
    Opensource STG 2, Epic Engineering
    Hawk-Eye Alliance #032
    http://s258.photobucket.com/home/joesubaru7/index
    DD: 2001 2.5RS
    Old: 1998 2.5RS [url]
  2. #47
    Registered User Yulri's Avatar
    Baton Rouge
    sorry didnt even see this... theyve been holding out pretty much the same...the only thing i've seen thats weird is that gasoline stains them and changes the color but i got some wheel cleaner and manged to scrub it out with a microfiber towel. Other than that they're exactly the same as when i first painted them. I cant honestly say how many cans i used but im going to guess 5-6 for primer probably the same for the paint and 7-8 for the clear coat.
  3. #48
    Registered User WRX_Karl's Avatar
    Jul 2008
    could i do the same thing with my gold superleggeras?
    i want to paint them black or somewhere along those lines
  4. #49
    May 2008
    Yeah
    I don't like the stock rims, I think you did a really good job painting them and I think it looks better then grey.
  5. #50
    Aug 2008
    i painted mine a few weeks ago and they turn out well. Saved me $800
  6. #51
    Wrinklechops
    Quote Originally Posted by Weasel 555 View Post
    Actually any color you like.... i just happen to like gold
    make sure you have a day to 2 days nice warm above 60F weather or if your lucky you have a nice warm garage !
    1.Go to Home Despot
    2.Find Spray Paint Aisle
    3.Choose paint i went with rustoleum (optional buy clear coat either matt or gloss)
    for a set of four wheels (i used 4 cans colored paint and 2 cans clear coat)
    4.Get 1." and 2" masking tape, 260 or fine sand paper sheets, get spray can spray handle attachment.
    Ok directions:
    1.Wash wheels inside and out with warm soapy water to clear off brake dust ,grime etc
    2.sand wheel outside and inside makes it easier for the paint to adhere
    rinse off wheel again with clean water and let dry.
    3.Once dry using the 1" masking tape nearest the wheel edge mask off where the tire meets the rim.
    4.once done use the 2" masking tape to mask off rest of the tire sidewall
    or optional use news paper. Then take some tape and mask off the valve stem.
    5.do same as steps 3.and 4. with inside of wheel/tire.
    (u can skip this step if your not gonna go all out for the "factory" look.)
    6.Painting I started from the rim and circled in until completly covered (after each spray i waited for it to dry)
    7.once i had done both the outside and the inside of the wheel and it was dry , i then used the clear coat for a more factory look.
    This is great! I wonder if I could do this to my stupid stock 16's from my 05 WRX...I'd love to see how they look in black or something...
  7. #52
    Flirty User That's Younger Than the Chunks of Corn in Brian's Crap
    WRXie's Avatar
    Mar 2009
    Down South
    Quote Originally Posted by lundholm08 View Post
    I'm thinking about that. Except I'm not sure if I would rather just keep them and just buy some.
  8. #53
    Apr 2009
    I was thinking of painting mine too... I love how those came out!
    I was wondering if anyone has ever had issues with the paint chipping off...(even after doing it the right way)
    I'm a New Englander....so I'm thinking about the sand & salt in the winter ...I've heard mixed responses from friends up here
  9. #54
    Wrinklechops
    Dumb question, what is that thing that is attached to the spray paint can? Like a bigger/better sprayer of sorts... expensive? effective? I'm going to go back and read after I write this, but how many coats have everyone used?
    edit: nevermind I just reread the original post. Sorry Weasel
  10. #55
    Wrinklechops
    Quote Originally Posted by utqb1 View Post
    Here are some pics of the ones I did.
    donde amigo?
  11. #56
    Mar 2009
    CO
    what do you do with the wieghts? just take them off for painting, then re-balance the wheels?
  12. #57
    Jul 2008
    San Antonio
    Is this still up to date... ie.... the best paint to use ... you know how they come out w/new paint every day.... What grit of sandpaper do you use ?
    Paul
    2007 MS3
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
  13. #58
    Registered User cam.rex.03's Avatar
    May 2008
    Western Washington
    I took A LOT of time to prep my wheels, used 100 grit paper first, then 220 to finish it off. The only place my wheels are chipping is around the outer edge of the rim, closest to the rubber. This is because it was a difficult area to sand down since my tires were on when I painted them. Other than that, I'm really happy with the results. I used dupli-color wheel paint in flat black. It's a tough spray paint and it splatters less than other general spray paints.
  14. #59
    Wrinklechops
    Quote Originally Posted by cam.rex.03 View Post
    +1 on the sanding. I used wet sand paper and water/soap too, to keep the dust down. And WEAR A MASK! I learned this the hard way.
    I used Rustoleum flat black, but Duplicolor makes good stuff too.
  15. #60
    Jun 2006
    D-VILLE, PA
    when I did mine last summer.
    One I took the other day.
    2006 WRX
    DD: 2001 2.5RS
