WRX brake pad differences
Page 1 of 5 12345 LastLast
Results 1 to 15 of 61
This is a discussion on WRX brake pad differences within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; The late 2002/early 2003 WRX have several different factory combinations of brake pads, making it difficult to shop for upgrades. ...
    Jul 2001
    Plains of Eastern Montana
    The late 2002/early 2003 WRX have several different factory combinations of brake pads, making it difficult to shop for upgrades. Here is a year-by-year breakdown to assist.
    2002: All 2002 WRXs have a combination of D721 front pads and D770 rear pads.
    2003: Starting in July of 2002 (2003 cars were made in 2002), Subaru decided on new brake calipers for both the front and rear, which consisted of a D929 front pad and D1004 rear pad. This created four variants of WRX brake setups:
    1. Some early 2003 cars got the 2002 style D721 and D770 setup
    2. Some cars got the older D721 front pads and the new-style D1004 rear pads
    3. Some vehicles got the new D929 front pads with the older D770 rear pads
    4. Some got the new D929s front and D1004 rear setup.
    These variants make purchasing brake pads and brake kits complicated; the easiest (and only) way to tell what you have is to remove the wheels and measure the pads. Generally any 2003 WRXs made after July of 2003 have the new D929 and D1004 setup that was used until 2005.
    2004-5: All 2004+ WRX Models use the D929 Front and D1004 Rear brake pad setup.
    In 06 the WRX went to the FHI 4/2 pot setup D460 Front, D461 Rear
    here's a site that has most of the FMSI's and jpegs for most make/models
    http://www.toeflex.cn/brake%20parts/brakepadsasia.htm
    Registered User Icysheet's Avatar
    Ridgecrest, California
    Thanks Big Sky, that's exactly what I needed to know.
    2006 SGM STi Cobb Stage II
    Registered User damnwrx's Avatar
    Feb 2002
    Corner of Walk & Don't Walk
    Would you happen to know if I can use any other types of brake pads on my BBK if so, please list options.
    MY02 Wagon
    BBK (STi)
    Thank You
    ......W...............R.................X.......
    2
    ********W***a****G****o*****N*******
    IHIVF22: PWR Radiator:Pulley: MRT top mount intercooler:
    Ecutek:GTspec headers-UpPipe:
    STI Injectors: Walbro Fuel Pump:
    ACT clutch /Flywheel:Tein Basic:
    Brembo-BBk:MotoforgeWheels:
    Jul 2001
    Lots of pad choices for the STi Brembos- Hawk, Ferodo, Carbotech, EBC, Pagid and many more
    the front pad is a D1001
    The rear is a D961
    Registered User BlueRex_03's Avatar
    Apr 2006
    ATL
    I just had to deal with this issue. I have a 03 made in 7/02. I ordered the 721 for the front and didnt fit, thats what came when i oredered them for a 03 WRX.. Searched all over town and one place had a set of the 929, but they were the organic ones. I had no choice had to get them. So if i have the 929 on front i should have the 1004 on the back right ? And who can i order from to ensure i get the proper size.
    Jul 2001
    Not necessarily- they really mixed/matched things up to the point your best to pull one pad (and compare to the drawings above) to insure what you have. SOA really screwed the pooch on this one IMO.
    Registered User yu1isys's Avatar
    Apr 2006
    Auckland, New Zealand
    do you know what type of brake pads u need for STi Version 6? This is the early 2000 model.
    Jul 2001
    Should be the same ones as the four/two pot ones
    Registered User fsidesmith's Avatar
    Jul 2004
    Burlington, VT
    Big Sky Props
    Thanks bro. Concise info with pad photos is sweet.
    Big ups from VT.
    Registered User negated's Avatar
    Mar 2003
    Seattle-area, WA
    Question
    Hey all,
    I went down to the dealership to ask what style pads I currently have on my Sonic Yellow '03 Sedan...I asked about the style types above (D721, D770, D929, D1004), and they looked at me like I had three heads. They gave me a print out based on my VIN with the Subaru part #s...the front pads are 26296/26300...the production date says "200204-200206".
    How does that compare? If I order online, do I ask for 2002 or 2003 pads? Are the front rotors the same for both years?
    My brakes are about to go and I wanted to order some new ones ASAP...
    Thanks!
    S.
    Jul 2001
    Geez- they don't even give you valid part #'s. The 2002 front pads- oe part # is 26296FE060- I think from that complete number and the partial number they gave you- you can gather that you have the "2002" style pad.
    Rotors are the same.
    Mar 2003
    Seattle-area, WA
    Question
    Quote Originally Posted by Big Sky WRX
    Nice. Thanks for the quick reply! I've been going crazy trying to figure this out...so that probably means I have the 2002 style rear pads as well? Does this mean that the clips I have now are only good for the 2002 style pads? I am planning on replacing the pads with Hawk HPS so I guess that means I should order the 2002 WRX front/rear pads along with my H6 upgrade...
    Big Sky, you're a big help!
    S.
    Jul 2001
    Unfortunately I don't think there was any rhyme nor reason on the rears. Best bet is to pull one side and compare w/ the drawings if you want to know for sure.
    If your going to the H6 setup you need 02 pads regardless- so if that is what your doing order the 02 rear pads. The clips (2002) are inexpensive so you could order those as well- worse case scenario you end up w/ a extra set of clips
    Registered User houdini's Avatar
    Jun 2004
    Los Alamos, NM
    I called 3 dealerships and got part numbers for my brakes (from VIN). Can anyone decypher which these are?
    Front: 26296 SA 000
    Rear: 26696 FC 002 (one place said 004 instead of 002)
    2003 White Sportswagon
    Mods: Cobb stg 2 (STX map), Whiteline strut braces, SRBs and swaybars, Kartboy rear endlinks, 04+ rear swaybar mounts, Hawk HPS brake pads meeting Powerslot front rotors, Bridgestone Potenza RE-01Rs, some stereo
    Pending: some more stereo. Front endlinks?
    Jul 2001
    Well I'd have to say that the front ones are the D929 as the part # for the 02 front (D721) is 26296FE060
    The rears- looks like the 02 style rears (D770) the part # is 26696FC002, 004 at the end doesn't come up as a vaild part #
