Page 4 of 4 FirstFirst 1234
Results 46 to 59 of 59
This is a discussion on WRX brake pad differences within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; So just to make sure with the pads. Are these the right numbers for the HAWK HPS pads. HK-178F564 -- ...
  1. #46
    Registered User 1_FAST_WRX's Avatar
    Mar 2009
    Pocono Mountains
    HK-178F564 -- Fronts
    HK-179F630 -- Rears
  2. #47
    Registered User c2bcoolwrx's Avatar
    Mar 2008
    SFLA
    Quote Originally Posted by 1_FAST_WRX View Post
    HK-179F630 -- Rears
    Yes, those are the correct pads for the 06-07 WRX.
  3. #48
    Registered User Tubbs540's Avatar
    Nov 2008
    Madison, WI
    Okay well i have a 2002 WRX and related to brakes i was asked what month my wrx was produced in. I had no clue.... I dont know where to even begin looking... is there a way to find this out or figure it out?
  4. #49
    Jul 2001
    Plains of Eastern Montana
    just open the driver's door there should be a plate w/ a bunch of info- including build date (will be month/year)
  5. #50
    Nov 2008
    Madison, WI
    Thank you! I feel kinda stupid that it was right there but thanks a bunch u just saved me a bunch of time.
  6. #51
    Registered User AKESREX's Avatar
    Oct 2004
    So. California
    Early 2002's used the D721's and after the split, they used
    the D929's.
    ex-Akebono Brake employee
    2002-2008
  7. #52
    Nov 2009
    Quote Originally Posted by ilia View Post
    Can somebody please give me advice about brake pads and rotors.
    I bought two months ago a 2003 Subaru WRX wagon 95k, and I am thinking about replacing the brake pads and rotors.
    As far as the rotors I am thinking about getting the Brembo 25190 Rear Solid Brake Rotor and Brembo 25646 Front Disc Brake Rotor.
    For brake pads I was looking at Hawks HPS or EBC red stuff.
    Does it matter which rotor comes with which brake pad? Can somebody give me more advice on how to choose new brakes and if I am heading in the right direction.
    Thanks.
    I know this is a long shot but if you still are on clubwrx do you have any feedback on the Brembo rotors you were going to buy?
    I found these and might pick them up.
    Amazon.com: Brembo 25646 Front Disc Brake Rotor: Automotive
    Anybody else try these rotors. Thanks for the help.
  8. #53
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    Ok, so I have a 2003, and I called the dealer with my VIN, and here's what I got:
    Front pads: 26296SA020
    Rear pads: 26696AE020
    These looked different from the other numbers posted, can anyone decode them for me? The dealer wants $170 for OEM pads, but I'm planning on getting the HPS's.
    I need to install them this week since I'm going to the mountains this weekend. Do any brick and mortar parts stores carry Hawks?
    I haven't found one yet...
    Thanks!
    Sent using Tapatalk
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
  9. #54
    Dec 2011
    Sorry to revive an old tread but can anyone tell me if those are relly D929 and D770 ? I think they are, Thanks I looked at this KNS Brakes.
ID:	100976Click image for larger version.
ID:	100977Click image for larger version.
ID:	100978Click image for larger version.
    edit: D770? Click image for larger version.
  10. #55
    Oct 2004
    So. California
    Pretty hard to tell with the pads still in the calipers.....
    Here's the diagram-
  11. #56
    Dec 2011
    Quote Originally Posted by Boby25 View Post
    KNS Brakes
    Front calipers - no divot on center leg = later pad - D929
    Rear pad - ears down low and wider = D770 old rear pad.
    That's the typical 03 setup.
    -Ken
  12. #57
    Jan 2009
    Md
    could we get an updated pad section for the 08 and up?
  13. #58
    Nov 2012
    A, A
    Hi I have a 03 wrx wagon and I understand the pad difference's but I think the previous owner put the wrong pads on because there's a clear gap between the rotar and the pad on the outside about 2mm, my question is can you tell by looking at the calipier what version it is.
  14. #59
    Jul 2001
    not that I'm aware- calipers look to my eyes the same
    if you're unsure you can run your VIN through Subaru- they should be able to tell you w/ some certainty
