| Home | Forums | Gallery | Register | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
| Suspension & Wheels Subframes, A-arms, uprights, shocks, struts, coilovers, swaybars, hubs, brakes, wheels, and tires! Sponsored by The Tire Rack |
| Advertise On ClubWRX | |
| Welcome to the ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums. | ||
Thread Tools | Rate Thread | Display Modes |
#1 |
Moderator
WRX brake pad differences
The late 2002/early 2003 WRX have several different factory combinations of brake pads, making it difficult to shop for upgrades. Here is a year-by-year breakdown to assist.
2002: All 2002 WRXs have a combination of D721 front pads and D770 rear pads. 2003: Starting in July of 2002 (2003 cars were made in 2002), Subaru decided on new brake calipers for both the front and rear, which consisted of a D929 front pad and D1004 rear pad. This created four variants of WRX brake setups: 1. Some early 2003 cars got the 2002 style D721 and D770 setup 2. Some cars got the older D721 front pads and the new-style D1004 rear pads 3. Some vehicles got the new D929 front pads with the older D770 rear pads 4. Some got the new D929s front and D1004 rear setup. These variants make purchasing brake pads and brake kits complicated; the easiest (and only) way to tell what you have is to remove the wheels and measure the pads. Generally any 2003 WRXs made after July of 2003 have the new D929 and D1004 setup that was used until 2005. 2004-5: All 2004+ WRX Models use the D929 Front and D1004 Rear brake pad setup. In 06 the WRX went to the FHI 4/2 pot setup D460 Front, D461 Rear ![]() ![]() here's a site that has most of the FMSI's and jpegs for most make/models http://www.toeflex.cn/brake%20parts/brakepadsasia.htm
__________________
"Simplify and add lightness." - Colin Chapman Last edited by Big Sky WRX; 09-13-2008 at 03:34 PM. |
#2 |
Thanks Big Sky, that's exactly what I needed to know.
__________________
2006 SGM STi Cobb Stage II |
#3 |
Would you happen to know if I can use any other types of brake pads on my BBK if so, please list options.
MY02 Wagon BBK (STi) Thank You
__________________
......W...............R.................X....... 2********W***a****G****o*****N******* IHIVF22: PWR Radiator:Pulley: MRT top mount intercooler: Ecutek:GTspec headers-UpPipe: STI Injectors: Walbro Fuel Pump: ACT clutch /Flywheel:Tein Basic: Brembo-BBk:MotoforgeWheels:
#4 |
Moderator
Lots of pad choices for the STi Brembos- Hawk, Ferodo, Carbotech, EBC, Pagid and many more
the front pad is a D1001 ![]() The rear is a D961
__________________
"Simplify and add lightness." - Colin Chapman |
#5 |
I just had to deal with this issue. I have a 03 made in 7/02. I ordered the 721 for the front and didnt fit, thats what came when i oredered them for a 03 WRX.. Searched all over town and one place had a set of the 929, but they were the organic ones. I had no choice had to get them. So if i have the 929 on front i should have the 1004 on the back right ? And who can i order from to ensure i get the proper size.
#6 |
Moderator
Not necessarily- they really mixed/matched things up to the point your best to pull one pad (and compare to the drawings above) to insure what you have. SOA really screwed the pooch on this one IMO.
__________________
#7 |
Hey all,
I went down to the dealership to ask what style pads I currently have on my Sonic Yellow '03 Sedan...I asked about the style types above (D721, D770, D929, D1004), and they looked at me like I had three heads. They gave me a print out based on my VIN with the Subaru part #s...the front pads are 26296/26300...the production date says "200204-200206". How does that compare? If I order online, do I ask for 2002 or 2003 pads? Are the front rotors the same for both years? My brakes are about to go and I wanted to order some new ones ASAP... Thanks! S. |
#8 |
Moderator
Geez- they don't even give you valid part #'s. The 2002 front pads- oe part # is 26296FE060- I think from that complete number and the partial number they gave you- you can gather that you have the "2002" style pad.
Rotors are the same.
__________________
#9 | |
Quote:
Big Sky, you're a big help! S. |
#10 |
Moderator
Unfortunately I don't think there was any rhyme nor reason on the rears. Best bet is to pull one side and compare w/ the drawings if you want to know for sure.
If your going to the H6 setup you need 02 pads regardless- so if that is what your doing order the 02 rear pads. The clips (2002) are inexpensive so you could order those as well- worse case scenario you end up w/ a extra set of clips
__________________
#11 |
I called 3 dealerships and got part numbers for my brakes (from VIN). Can anyone decypher which these are?
Front: 26296 SA 000 Rear: 26696 FC 002 (one place said 004 instead of 002)
__________________
2003 White Sportswagon Mods: Cobb stg 2 (STX map), Whiteline strut braces, SRBs and swaybars, Kartboy rear endlinks, 04+ rear swaybar mounts, Hawk HPS brake pads meeting Powerslot front rotors, Bridgestone Potenza RE-01Rs, some stereo Pending: some more stereo. Front endlinks? |
#12 |
2006 wrx pads
I have a 2006 WRX with the 4 pot fronts and the single pot rears. And I have looked everywhere to get pads I have 929 for the front which dont fit. and 1004 for the rears which dont fit either. What pads do I need for the front and rears. This is the first time the pads I havent gotten for my subi that dont fit.
#13 |
Moderator
the 06 has four pot fronts and two pot rears- not sure how you came up w/ one pot rears?????
the 06 (4/2) uses D460 Front, D461 Rear
__________________
#14 |
Are those for all 06 wrx including, limited wagon, and reg limited.
__________________
06 WRX limited- Cobb t-back/accessportV2 -17x9 Emotion- Eibach Coilovers System 250hp/348tq Topspeed tuned by Scott Seigal 13.2 -102mph Hawk-eye Alliance #131 |
#15 |
Moderator
should be- take a pic of your rear caliper I can tell if it's a two pot or not
__________________
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Brakes! Carbotech, Goodridge, TWRR, PDE, Speed Bleeder, Hawk | OakosAutomotive | Vendor's Forum | 23 | 07-30-2008 09:12 PM |
| 2002 rear brake pad difference | Icysheet | Suspension & Wheels | 1 | 02-18-2006 06:56 AM |
| Brake Parts! Carbotech, Goodridge, Speed Bleeder, RacingBrake, ATE! | OakosAutomotive | Vendor's Forum | 4 | 08-26-2005 08:25 AM |
| Brake Pad Wont Fit?? | fino22 | Suspension & Wheels | 8 | 06-10-2005 06:10 PM |
| Spongy brake pedal after pad replacement... | PPMotorsports | General Maintenance, Troubleshooting & Accidents. | 6 | 02-18-2004 05:06 PM |
