Suspension and Handling Technical Reference - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
This is a discussion on Suspension and Handling Technical Reference within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; A new and improved tire/wheel calculator http://www.gti-vr6.net/library/engin...ldiameters.htm...
  1. #31
    Jul 2001
    Plains of Eastern Montana
  3. #32
    Jul 2001
    Common (and not so common) Subaru pads- thanks to perfusionista for posting it up
  4. #33
    Jul 2001
    Koni insert install
    The one link is dead at the moment but I'll still post in the chance it might come back up
    http://paul.the-nest.com/Subaru_2002...erts_page1.htm
    These are below are not suby specific, but the process is very similar
    http://www.roadraceengineering.com/3...3gkoniinfo.htm
    http://www.gp-owners.com/upgrades/struts/
    Here's one w/ no narrative, but pics
    http://album.pattiandken.com/thumbnails.php?album=100
  6. #34
    Jul 2001
    How to convert spring rates
    You'll often find spring rates listed kg/mm or N(Newtons)/mm- here's how to get them into any unit you want
    To convert kg./mm. to.......lb./in. ......N./mm.
    multiply by ................55.998........9.807
    To convert lb./in. to ......Kg./mm. ......N./mm.
    multiply by ................0.017858......0.175133
    To convert N./mm. to .......Kg./mm. ......lb./in.
    multiply by ................0.101968......5.7099
  7. #35
    Sep 2006
    Reno, NV
    are the suspension torque settings in the 1st couple of posts the same for the 2006 wrx? i just purchased prodrive springs and would like to know the torque settings for all the bolts in the install and hope these are the same.
  8. #36
    Jul 2001
    same
  9. #37
    Jul 2001
    appears the tire/wheel calculators links are all dead- try this one
    http://gti-vr6.net/library/engine/Sc...ldiameters.htm
  10. #38
    Jul 2001
    How to repair a hi po tire, from this link
    http://www.goodyear.com/cfmx/web/gov...e/psb_9811.cfm
    TO:
    Goodyear Company Owned Outlets
    Goodyear Contract Dealers
    Kelly-Springfield Dealers
    Dunlop Dealers
    SUBJECT: Puncture Repairing and Retreading of tires that are "H" Speed-Rated and higher (equal to or greater than 130 mph) includes Goodyear EMT & Dunlop DSST tires
    With the ever increasing popularity of Speed-Rated tires, it is important for you and your customers to know how repairing and retreading will affect the speed rating.
    Accordingly, the following information will enable you to discuss these important subjects with your customers.
    I. SUMMARY STATEMENT
    REPAIR
    A Goodyear, Dunlop or Kelly-Springfield manufactured speed-rated tire may be repaired to correct a commonly repairable nail hole puncture in the tread area only, but proper materials and procedures must be applied. INCORRECT OR IMPROPER REPAIR WILL RESULT IN THE TIRE NO LONGER BEING SPEED-RATED BY GOODYEAR, and the warranty may also be affected.
    RETREADING
    If a Goodyear, Dunlop or Kelly-Springfield manufactured speed-rated tire is retreaded, it no longer is speed rated by the company.
    II. DETAILED POLICY - Puncture Repair of Speed-Rated Tires
    The puncture must be confined to the tread area only.
    (See "Repair Area", item III-B).
    Restrictions on the number and size of repairs must be followed.
    (See "Puncture Repair Limits" table, item III-C).
    A detailed repair procedure must be followed.
    (See "Repair Procedure", item III-E).
    A speed-rated tire repaired in strict accordance with items II-A, B & C will retain its speed rating.
    III. REPAIR PROCEDURE FOR SPEED-RATED TIRES
    GENERAL
    The objective of the puncture repair is to seal the tire against loss of inflation pressure and to prevent damage to the carcass from moisture. In all puncture repairs, approved by Goodyear, Dunlop and Kelly-Springfield, the hole must be filled with a plug, and a patch covering the hole must be applied according to repair material manufacturer instructions to the inside of the tire. Never repair tires which are worn below 2/32" tread depth.
    NOTE: NO TIRE IS TO BE REPAIRED WITHOUT FIRST BEING REMOVED FROM THE RIM.
    REPAIR AREA
    Repairing is limited to the tread area only within the outside grooves. No repairs are allowed in the tread area beyond the outside grooves or in the sidewall area of the tire.
    PUNCTURE REPAIR LIMITS
    TIRE SPEED (SPEED SYMBOL)
    MAX. NUMBER REPAIRS
    MAX. REPAIR DIAMETER
    130 mph (210 km/h) and over (H, V, W, Y, Z)
    1
    1/4 in. (6mm)
    MATERIALS
    Precured rubber plugs - 1/4" (6mm) diameter
    Precured patches
    Precured plug/patch combi-units
    Chemical vulcanizing cement
    Pre-buff cleaner
    REPAIR PROCEDURE
    CAREFULLY REMOVE THE TIRE COMPLETELY FROM THE RIM.
    Locate the puncture on the inside of the tire and circle with crayon.
    Remove puncturing object if it is still in the tire.
    Carefully inspect tire on a good tire spreader, with ample light, which will show any cracks, breaks, punctures, damaged or broken beads.
    Check liner for cuts, cracks, or holes which may cause the tubeless liner to lose air.
    Check the injury with an inspection awl:
    Determine size and angle of injury
    Check for ply or belt separation
    Reject any tire that has separation, loose cords, damaged bead(s), or any other non-repairable injury.
    If the hole is simple and round, steps 9 through 17 of the puncture repair procedure will be successful.
    NOTE: If the hole shows evidence of fabric splitting, such an injury cannot be properly repaired using this puncture repair procedure. Such an injury must be skived out and repaired as a section (reinforced) repair, which will maintain the serviceability of the tire, but will invalidate the tire's speed rating. If a section repair is necessary, the customer must be advised, before the repair is made, that the tire will lose its speed rating, and must not exceed operation at normal highway speeds.
    Use a pre-buff cleaner and a scraper to remove contaminants from the liner in the area to be buffed around the injury.
    Use a 7/32"carbide cutter for ¼" repairs to clean out the puncture.
    Make sure that the drill follows the direction of the puncturing object.
    Always drill from inside to outside of tire.
    Using chemical vulcanizing cement, lightly coat at least 1/2 of the tapered end of the repair plug. Install the plug in the prepared puncture according to the manufacturer's instructions. Trim the liner side of the plug slightly higher than the surface of the liner without stretching the plug.
    Center the patch (or patch template) over the injury without removing the backing. Adhere to patch or template instructions, as to positioning as related to bead location. Using a marking crayon, mark around the outside edge of the patch, approximately 1/4" larger than the patch.
    Buff the liner and plug at the puncture location. The buffed area should be slightly larger than the patch. The buffed surface should be finely grained (RMA 1 or 2 texture) and even for proper bonding. Use care to prevent burning the rubber with the buffing tool. Do not buff through the liner. Do not buff into the marking crayon.
    Clean the buffing dust from the tire using only a vacuum or brush. Do not use gasoline or other petroleum solvents on the buffed area.
    Coat the buffed liner surface and the patch with one evenly applied coat of chemical vulcanizing cement in accordance with the recommendations of the repair materials manufacturer. Allow the cement to dry thoroughly. Do not touch the cemented areas.
    Install the patch with the beads of the tire in the relaxed position. Position the patch over the puncture according to the markings on the patch.
    Stitch the entire patch starting from the center, keeping the strokes close together to avoid trapping air under the patch.
    Cut off the protruding end of the plug about 1/8" above the tread surface.
    FINAL INSPECTION - The repair must seal the inner liner and fill the injury. After remounting and inflating check the repair, both beads and valve with a soap solution to assure a complete seal.
  11. #39
    Jul 2001
    a nice spring rate calculator- http://www.dfaulknersprings.co.uk/convert.htm
