Results 1 to 15 of 26
This is a discussion on 04+ brake duct setup within the Suspension and Handling forums, part of the Tutorials & DIY category; This tutorial will be similar to the one I did for 02/03's-http://www.clubwrx.net/forums/showthread.php?t=62506 What you'll need: a set of oe fog ...
    Jul 2001
    Plains of Eastern Montana
    What you'll need:
    a set of oe fog surrounds
    3' of brake duct- you don't need high temp ducting, regular will do- either 2 or 2.5"
    www.racerpartswholesale.com/duct.htm
    2 duct reducers either 3->2.5" or 3-> 2"
    www.racerwholesaleparts.com/naca.htm
    2 plastic "connectors" found at the hardware store- don't really know what their application is (they were threaded on the inside)- anything that will fit into the duct end and then into the wheel well
    four appropriate size hose clamps
    The reducers will fit into the oe fog surround, you'll have to do a little bit of filing/dremeling for them to fit, squeeze the reducer and it will go in it will be snug
    Jul 2001
    from the rear
    Jul 2001
    view from bottom- I drilled a small hole and used a plastic fastner (same as used on the rubber intercooler seal) to help keep it in
    Jul 2001
    You'll need to remove the fog lamps, I've elected to leave mine out (never used them as they were covered)- you could remove them for track days easy enough and then put them back in
    Use ~ 18" of your ducting and fastener the "connector" to it w/ a hose clamp
    I angled mine to help direct the air
    Jul 2001
    Use a hole saw on a drill (wheels need to be removed)- either 2 or 2.5" depending on the ducting you went w/- you may have to doa little filing w/ a round file depending on the "connector" you have chosen
    You can see from the pic where this is located when you look at your wheel well- this keeps well out of the tires way
    Jul 2001
    from the front push the "connector" end into the hole- should look something like this:
    Jul 2001
    Now all you have to do is connect the other end to your reducer
    Jul 2001
    snap the surround in and voila
    Jul 2001
    Day to day driving I use the STi covers- leaving the ducting in place, track day just unsnap the cover and attach the ducting to your oe surround w/ reducer- two minutes and functional brake ducts
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    Nice job. A similar setup can be made for the bugeye models using the mesh fog covers to prevent debris from going through, not that it would be a big deal.
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
    Jul 2001
    Quote Originally Posted by AjIsDope
    That's the way I ran it on my 02
    Aug 2002
    SoCal
    Ah-ha!
    Registered User coolblue04's Avatar
    Mar 2003
    near Toledo, OH
    Nice work, nice tutorial. I just can't bring myself to remove my JDM fogs...
    Tuned Perfection Autosports
    2005 Sti Widebody
    Jul 2001
    Quote Originally Posted by coolblue04
    It'd still work if a guy wanted to run his fogs day to day, you'd just have to take them out for track days (they wouldn't get busted that way too)- would only take a couple of minutes to remove them
    Registered User GotWRX03's Avatar
    Apr 2003
    USA
    i've been thinking of doing this to MY03 for quite sometime now, just haven't had the time to get around it - and was actually contemplating whether it is worth the trouble..?
    noticed any difference Big Sky?
