Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 46
This is a discussion on Rear Sway Bar/EndLinks Install within the Suspension and Handling forums, part of the Tutorials & DIY category; nope, no squeaks. not much oversteer, but I can definitely tell the difference from stock. the car's more to the ...
  1. #31
    Registered User GotWRX03's Avatar
    Apr 2003
    USA
    nope, no squeaks. not much oversteer, but I can definitely tell the difference from stock. the car's more to the neutral side.
    Quote Originally Posted by WRXreX
    any squeaks? is oversteer that noticeable? how about body roll? I am installing mine this weekend.
  2. #32
    Nov 2004
    Arizona
    Just to follow up, I have had no problems with the Perrin rear sway bar and endlinks after my install. I just finished the front sway and endlinks, and I can't believe the difference just driving around the street. I have the rear set in the middle and front set full hard and the car is on rails, at least to me. We'll see what happens when I AutoX in Phoenix this weekend.
    Gotta love AutoX in January.
  3. #33
    Registered User toolow67's Avatar
    Aug 2004
    near Pottstown, PA
    can u post some pics and tips for the front install? thanks
    2005 STi, WRB with Gold Wheels, MY05 Cobb Accessport Stage 1 , JT-X Carbon Fiber Hood (CF1), 20% Tint, Invidia N1 Race Catback, Cusco front and rear stut bars, Cleared Headlights, Pink "i" Symbol, JDM Hazard light button, Black "STI" License Plate piece, Mine's Carbon Fiber Spoiler
  4. #34
    Registered User WRXcelration's Avatar
    Apr 2004
    Allentown PA
    the click noise is probably a loose endlink bolt...hit it w/ a torque wrench and your set
    05 STI
    Speed Comes At A Price...How Fast Can You Afford To Go?
  5. #35
    Registered User turbo_bxr's Avatar
    Aug 2004
    hamilton,oh
    at 40-45 mph in my car with plenty of room i can get sideways holding 4th gear, done it 3 or 4 times now, but i just have the bar kit. no pretty perrin links...
  6. #36
    Registered User Richie03's Avatar
    Feb 2003
    PA
    I am considering getting the perrin / progress rear swaybar. I am concerned with the mounting brackets. They look like they hang alot lower then the stock brackets and any other aftermarket brackets out there. I want maximum ground clearance.
    Has anyone experienced any ground clearance issues with the perrin / progress rear sway bar set up?
  7. #37
    Aug 2004
    hamilton,oh
    if you ever have ground clearence problems, then you need to come back to the streets and stay off good the good old rocky mtns.... my only problem is the bar hits the rubber hanger for the exhaust
  8. #38
    Feb 2003
    PA
    I have decided to go with the Cobb front and rear sway bar combo (hotsubaru.com 4th O July sale). The rear sway bar mounts in this package don't hang as low as the perrin / progress mounts.
    Thanks for your input turbo_bxr
  9. #39
    Registered User wrxrolla's Avatar
    Ames, Iowa
    The newer perrin mounts (the ones that dont look like P's) don't hang any lower than stock.
    Andrew
    Never quit. Never do the expected. Never follow.
    http://www.cardomain.com/id/wrxrolla
  10. #40
    Aug 2004
    hamilton,oh
    Quote Originally Posted by Richie03
    NP G/l with your swaybars!
  11. #41
    Registered User blahblah's Avatar
    Sep 2003
    Chi-cago
    i think that noise is the bar hitting the bottom of the car, i dont like the thought of that, but the bar seems to be pretty close to the bottom of the car in the middle. I dont think that its loose bolts, because i tightened em up real well, and it only makes the noise on bumps. Anyone else concerned by this?
    282 AWHP...267 lb-ft torque.
    2005 WRB WRX Sedan
    "he's a domestic fan with a hunger for rice"
  12. #42
    Aug 2004
    hamilton,oh
    man i got my endlinks and wow big diff. when they wear in a bit.... im loving them... what size front bar do you guys reccomend or should i just get hthe perrin front adj. with links also and put it on the light setting?
  13. #43
    Registered User Flat4-Wagon's Avatar
    Nov 2006
    El Dorado County, CA
    Just changed my RSB, 2005 wrx wagon. Changed to a 2003 sedan RSB.
    The '05s have 2 bolts on each ofthe bushings, one takes of the bolt and the other takes off the nut. The nut has about 1/2 inch of exposed thread and requires a 12mm deep socket, just a heads up!
  14. #44
    Registered User efaroh's Avatar
    Jan 2008
    OC
    That was a great walkthrough. I did a rear sway bar install and made a walkthrough as well.
    Rear Sway
  15. #45
    Wrinklechops
    Yea, it is my conclusion that the rear swaybar is really simple. At least, compared to the front.
    Man what a PITA the front is. I started this afternoon and gave up about 11pm. Gonna have to finish it tomorrow.
    Damn stripped bolts and nuts and rounded heads...
