passenger side, another shot
This is a discussion on Rear Sway Bar/EndLinks Install within the Suspension and Handling forums, part of the Tutorials & DIY category; passenger side...
passenger side
That's it!
Bang up job!! Doing mine this coming Sunday (Helix 22mm w/ endlinks) w/ a friend. Good to have some reference pics, even though my friend (ex-mechanic) doesn't seem to think there's anything to it. Hope he's right![]()
I'm TheBoostCreep, and I approved this message.
WOW...!!!! nice job, some one should make these PHOTO Tutorials into a PDF file... this info is great.
i got a question i did mine the other week and i hear clinking noise, when i hit pot holes at
idle speed just rolling i am wondering if i have to tighten the links even more??
how is the difference in handling, .... noticable?
"Mike, stop spending money on your car.."
this seem to be a common thing. based on what I've read before, you have to move the swaybar stiffness to the middle position. i am using the hardest position with no problems - so I'm not sure what the difference is.
Originally Posted by matt6000
the car induce more oversteer now.. or to me, the car feels more neutral. it's tight on corners too..
Originally Posted by surfingguy101
Yeah, I have my rear sway bar in too...f*ckin love it
LOVE IT!![]()
--------Transmission Complete----------
Lt Boom Sticks 2006 WRX Limited mods
Lt. Boom Stick 02 Mods
Pics of Lucy
this is a great thread, thanks for the tutorial....what tires are those...quite the sick tread design
thank you. the tires are Hankook K106. They just came out when I got mine. apparently, a lot of the MINI-C guys use these tires.
Originally Posted by Redline927
do you have a pic of the whole setup from under the car? like lookin at it from the back?
I just did this tonight with the Perrin Sway and Endlinks. There are a few things that probably should be added.
With my kit, the down bracket to chassis bolts that you must use actually needed a 13mm socket head, which I don't think is mentioned in the install guide. So I would recommend have a 12mm ratcheting to remove the stock brackets and a 13mm racheting wrench to put in the new brackets. The passenger side brackets are in a PITA position.
Everything went great with the no problems, wierd noises are anything else.
HOORAY!!!
any squeaks? is oversteer that noticeable? how about body roll? I am installing mine this weekend.
02 WRX - Tuned by Junior 301whp
Visit my install pages:
DIY: STi TMIC install on WRX with WRX Samco IC hose DIY: STi TMIC install on WRX
DIY: Pink injector install DIY: VF34 turbo install DIY: Front lip for $8 DIY: JDM blinker DIY: make your own catch can for <$25!
