Page 3 of 8 FirstFirst 12345678 LastLast
Results 31 to 45 of 113
This is a discussion on WRX Wagon Aluminum control arm install within the Suspension and Handling forums, part of the Tutorials & DIY category; Originally Posted by psychobooe Big Sky, You're a gift to the Subaru community. Your knowledge of all things suspension/brakes is ...
  1. #31
    Aug 2005
    Culver City CA
    Quote Originally Posted by psychobooe
    Big Sky,
    You're a gift to the Subaru community. Your knowledge of all things suspension/brakes is without comparison.
    psycho
    +1 thanks.
  2. #32
    Registered User Wrinkleboi's Avatar
    Jan 2002
    Langhorne, PA
    dont want to muck up this thread too much but maybe this will help others looking for guidance.
    i finally got it off... whether it was my raw persistance or the WD40 working overnight... i spent about 10 hours on this yesterday and about an hour so far today and it finally came off!!!
    just thought i'd post some photos of the carnage so nobody things i'm completely incompetent...
    as far as greasing the new one... where do i grease and wehre do i not grease? i naturally greased the cylindrical ball joint housing before sliding it into the knuckle, if for nothing else then for rust prevention in the future. right or wrong?
    anyways, pics:
    -2003 Blue WRX, complete 2007 STi Engine/Drivetrain transplant - Pic 1 | Pic 2 | Pic 3 | Pic 4 (new!)
    -1994 Black Supra TT 6MT - Pic | Build/Restoration Thread: 67mm, Fuel, Painted Engine Bay, Fuse Box Relocation, Wire Tuck, etc.
    www.TriStateTuners.com
  3. #33
    Jul 2001
    Plains of Eastern Montana
    The ball joint is internally greased, but some into the knuckle might prevent what happened to yours.
    Our roads may suck here in the winter (no salt), but we don't have to contend w/ rust issues like that
  4. #34
    Registered User Hybrid-X's Avatar
    Feb 2002
    Very nice writeup. One thing I'll add is that if you're planning to get an ALK, do it while installing these babies. I did and it was so much easier not having to do the same thing twice. :x Also, the fact that I don't have a subframe anymore made it somewhat easier.
    Great spirits will always encounter violent opposition from mediocre minds.
    Gas, grass, or ass. Nobody rides for free.
  5. #35
    Jul 2006
    I'm having the same trouble with my 140000km '02. How the h*ll do you get that ball joint out?
    -Walter
  6. #36
    Jan 2002
    Langhorne, PA
    If its like mine then rust is the culprit. Get some PB Blaster or something made to dissolve rust, and use it liberally. The longer you let it soak the better, but I'd say spray it down well every couple of hours. Also try to pull down straight on the joint. I dont think it helped that I was actually prying on mine at a slight angle, not perfectly downward.
  7. #37
    Jul 2001
    There is a seam in the knuckel that the ball joint bolt tightens to capture the ball joint- if you have someone pry this seam w/ a large flathead screwdriver or pry bar (don't have them go to crazy prying) while you have a large rubber mallet striking down on top of the arm.
    If it's very rusted, your in for a battle.
  8. #38
    Jul 2006
    It has defeated me. I'm reinstalling all the old crap on my car. No aluminum arms for me.
    I've broken 2 screw drivers, gone through half a can of rust remover. Used everything I can possibly think of to get this thing out. Including iron wedges.
    The ball joint descends maybe 1/32 of an inch but that is all. I give up.
  9. #39
    Apr 2003
    Isn't is possible to change these things without removing the subframe??? there is a plastic cover on the subframe that you can take off to get access to the mount bolts.
    My control arms came in today finally, just waiting on my ball joints now... I'm going to see if I can do it w/o removing subframe.
  10. #40
    Jan 2002
    Langhorne, PA
    the subframe takes 10 minutes to remove (5 with air tools), and i can only imaging it will be in the way during the install if you leave it... so why not just take it off?
  11. #41
    Apr 2003
    Quote Originally Posted by Wrinkleboi
    Well I guess we will find out, Seems like if they went out of their way to make it to where you could take it off without removing the subframe then why not?
  12. #42
    Jul 2001
    You can access the rear bushing through the subframe, but it needs to come off to remove/install it.
    When your installing (removing) the control arms remove the arm out of the knuckle by the method outlined here- there is no need for a pickle fork/ball joint remover.
  13. #43
    Oct 2005
    Had to laugh a bit at 'bludgeon'
    Perhaps doing this 'sooner' rather than 'later' is a good idea.
    I only had half a New Jersey winter.
    I do admire the OP's persistence. That thing is seriously rusted.
    I'd expect Elise like handling after that much pain
  14. #44
    Jul 2001
    The OP's arms came out/went in easy Wrinkleboi on the other hand !!!!
    My wagon handles just like an Elise (well it would if it weighed 1892 lbs
  15. #45
    Apr 2003
    Damn, everything has come out relatively easy, except for that damn bolt and nut on the bushing. It must be torqued at over 200ft/lbs or something.
