Straight Forward Spring Install! Sedan 02-05 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
This is a discussion on Straight Forward Spring Install! Sedan 02-05 within the Suspension and Handling forums, part of the Tutorials & DIY category; BTW... bo.. those cobb springs or prodrives? Let's see an after pic buddy!...
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Registered User AgentH's Avatar
    Feb 2005
    Philadelphia Area
    I ended up using Sinister's link he has for the spring install because of the pictures. LPPTundWRX, your pics don't work, but thanks anyways. I think replacing the struts, springs, and tops has contributed to the largest improvement in my Wagon. Soooo sweet! Thanks again!
    2nd WRX...
    More than meets the eye.
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by AgentH View Post
    I used that guide for my Pinks install. It was a good guide!
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  6. #19
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    I broke soo much junk craftsman hardware getting those 19MM bolts off I'd say a impact is a must have.
  7. #20
    Registered User Shekina's Avatar
    Jan 2006
    Hamilton, Ohio
    my 19mm nut were torqued by King Kong himself! impact gun couldnt even bust one! so my bro-in-law took the floor jack handle of and used it as a breaker bar along side a old piece of chain link fence pipe. the nut was able to support his weight until he started bouncing on it! then it finally broke loose. good times.
    ps - my rear struts clunk like crazy still! it sounds liek the spring is separating from the spring and "clunking" when they come back together. but i dont see how cause we torqued everything to spec. bad strut? maybe?
    My Myspace
    Wingl3ss @lliance #6
    MODS:VF39 Turbo, 650cc DW injectors, SSAC FMIC, Cobb Short Ram Intake, GFB StealthFX Hybrid, NGK One-Step-Colder Plugs, Walbro Fuel Pump, Perrin Up-pipe, TurboXS 3" TBE Catless, Blitz SBC-id 3, Protune by Mead Engineering.
  8. #21
    Feb 2005
    Philadelphia Area
    Yea, seriously! In the rear, I took my 19" open end and stuck it on the bolt head and pointed the wrench towards the car so that if the nut and bolt would start to turn, it would jam it's self on a tie rod or drive shaft. Then I used the floor jack and a breaker bar to break the nut loose. There wasn't a single one of those nuts that wasn't torqued down by King Kong. But the ones in the rear were rediculous.
    I get a little Clunking still. But not like before. My only guess for now is, maybe there is some slack between the top mount and the strut shaft.
    2nd WRX...
  9. #22
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Pics work fine on my end. If you needed any help Im only a PM away, sorry this didnt work for you.
    Sinister: Im sure you have seen my cars pics plenty
    The springs are SPRINT. Yes they ARE garbage
    Lead Wrench @ WTF Tuning, LLC
  10. #23
    Dec 2004
    Medford, Oregon
    Quote Originally Posted by BrianH View Post
    Im sure you have seen the pics, I dont have an issue getting the 19's loose But like I said 1/2" impact is a nice feature.
  11. #24
    Oct 2003
    Way up high.
    Quote Originally Posted by LPPTundWRX View Post
    Yep, the day after I did my suspension install I bought the air tools
  12. #25
    Dec 2004
    Medford, Oregon
    Next time right??
  13. #26
    Nov 2005
    Central Florida
    good write up izzo
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
  14. #27
    Nov 2006
    Denver Metro Area
    worked fine for me too...
    I have... now
    do I see some quality springs or coilovers in your future bo?
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  15. #28
    Feb 2005
    Philadelphia Area
    It's funny, I'm at work now and they work fine. Normally it's the other way around and images don't come through when I'm here. Maybe the site you hosted them on was down when I was checking them out. Maybe my comp's a pos...? Anywho, Thanks again!
    2nd WRX...
  16. #29
    Jul 2001
    Plains of Eastern Montana
    pics not working for me- anyone else?
  17. #30
    Feb 2005
    Philadelphia Area
    Not working here either...
    2nd WRX...
