This is a discussion on psi in tires within the Suspension and Handling forums, part of the Tutorials & DIY category; wut psi does everybody have their stock wrxs in their tires? can i do 40psi all around?...
2005 Ubaru Impreza WRX Sedan Crystal Grey Metallic
Mods: In my profile
http://www.myspace.com/scottycruz
All We'll Drive
DIFFERENT STROKES
POST WH0RE KING
All We'll Drive
DIFFERENT STROKES
POST WH0RE KING
thanks. im gonna check mine again tommorrow. i used to run 28-30 but time to go up until snow. really cant wait for it this winter.
07 white STi in CT
NEWS FLASH:
ClubWRX has a Suspension and Handling forum for questions that deal specifically with...you guessed it...suspension and handling.
"I don't think he knows how to give up. His mind and machine are racing as one." -Takahashi Ryosuke
moved to correct forum
All We'll Drive
DIFFERENT STROKES
POST WH0RE KING
old thread![]()
but anyways in the door sill of my legacy it says to run 32psi front and 30 psi in the rear... maybe I'm just imagining things but it seems to handle better in the corners with this setup compared to say running 40psi all around like I used to be doing, any thoughts?
i agee on my wrx i run 32 all around and seems to coner and handle very well. If you are runnig to much psi then you will get uneven wear so if you are unning the psi that the door jam says and your tires wear unevenly you might be able to get it covered under waranty seeing as how tires arent all that cheap although most dealers around here are ******** and wouldnt do that but its an idea
36psi works really well for aggressive driving.
Check the door jam on the driver side, it should specify, if i remember correctly its 32 in front and 29 in rear..
