DIY: Subaru Ball joint removal tool for around $18 + 1 lug nut
Results 1 to 15 of 18
This is a discussion on DIY: Subaru Ball joint removal tool for around + 1 lug nut within the Suspension and Handling forums, part of the Tutorials & DIY category; So let me start off by saying that I am not against buying tools, quite the contrary actually. But I ...
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    So let me start off by saying that I am not against buying tools, quite the contrary actually. But I always find myself with a pile of parts and sans at least 1 tool I need. Said tool is never locally available, and I usually don't have the time to wait for it to come in, as was the case this time.
    Now they say necessity is the mother of all invention and that is certainly the case here. I bought ball joints forgot the puller, can't wait. So what to do? Well head to Lowes ofcourse.
    After trolling the webz and seeing what the Snapon tool, the old no longer available TIC tool, and the crappy EBay one looked like, I said "pffft I can make that." So I did and it works awesome.
    You'll need (I went to Lowes, Isle 12 but you can get this stuff most anywhere):
    1@1-1/2x4 pipe nipple
    1@1-1/2 pipe coupling
    1@1-1/2 galv pipe cap
    1@1/2-13 all thread 1' lg (cut to 8")
    1@12x1.25mm Subaru lug nut
    1@1/2-13 nut
    2@1/2" washer
    So step 1 is to weld the lug nut to the end of the all thread. If you don't have a welder, find a buddy and buy him a beer.
    The parts:
    Step 2:
    Assemble the pipe coupling and nipple and tighten.
    Step 3:
    Drill a 1/2" hole in the center of the cap for the all thread to pass through.
    Step 4:
    Screw cap onto nipple.
    Step 5:
    Trim the all thread to 8" with a hack saw or sawzall.
    Step 6:
    Grind flats for crescent wrench on ends of all thread.
    Step 7:
    Test assemble everything.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Jun 2006
    Nor Cal
    Step 8:
    Use the damn thing.
    First thread the lug nut onto the ball joint stud.
    Then slip the housing over and install the washers and nut.
    Then tighten like this:
    Use a crescent wrench and 3/4" wrench.
    Ball joint will pop right out.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    bloody hell thats easier than the snap on tool to use!
    Jun 2006
    Nor Cal
    I've never used the snap on one, what's it like?
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Nov 2012
    Pita. One size fits all multi tool. In a big suitcase kit. Its a great kit for service in a alignment/suspension shop. Nothing I'd buy for my garage. This is way better, totally built to the vehicle. And not snap on priced. Yay!
    Nov 2008
    Quote Originally Posted by tirerob View Post
    You can get the TiC removal tool or the Ebay kit which seems to be very popular at Nasioc & IWSTI which are less than half of Snap-on.
    http://www.amazon.com/Subaru-Ball-Jo...aru+ball+joint
    Jun 2006
    Nor Cal
    Quote Originally Posted by el Forester XTi View Post
    Subaru Ball Joint Removal Tool STI Limited Edition | eBay
    I didn't have the time to order when I came up with this. It's stronger than eBay, locally available, and half the price.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Moderator Donkey's Avatar
    Da boonies,Va
    Nice! I generally just remove the bolt from the hub/spindel and use a long breaker bar on the A arm. Pulls the ball joint right out. Then just remove the castle nut pop the ball joint of the A-arm.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2008
    Anybody knows the difference between the blue and pink tool on the Amazon's Ball Joint Puller? They have them listed under the same Part Number?
    Subaru Ball Joint Puller Removal Tool - Amazon.com
    Jun 2006
    Nor Cal
    Boys get blue girls get pink.
    or pink is for JDM ball joints...
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Registered User gregroot198521's Avatar
    Feb 2011
    El Paso, TX
    Quote Originally Posted by 06wrx4me View Post
    Lol!
    They are different versions of the same thing. Guy that makes them updated them to the pink one, notice the thicker plate on top for leverage. Apparently people were bending in the washers on the blue/yellow version (not because of the color, just materials). Tube may be made of thicker material in the pink version also.
    So basically blue/yellow=version 1, pink=version 2. Think I recall the dude that makes these said that on one of his eBay listings, or I asked him (don't recall which), either one he wrote it somewhere.
    Hawkeye Alliance #1050
    Build Thread
    http://i1108.photobucket.com/albums/...ps665d9b9d.jpg
    Always dirty, never scurred......
    Jun 2006
    Nor Cal
    I say build your own like this threads about
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Feb 2011
    El Paso, TX
    I agree, yours seems to be a lot beefier, and I'll probably build one like yours later on. I was just answering dudes question legitimately.
    Build Thread
    Nov 2008
    You need this tool in Texas?
    Jul 2015
    Built this tool after I tried pickle forking the ball joint out of the knuckle, vise-gripping it to turn it, pipewrenching, hammering a chisel, a screwdriver and a punch on the BJ itself, all while PB blasting it for a couple of day and beating the bejesus out of it with a hammer, thing wouldn't budge (2005 Sub Forester 175k probably original, Ohio winters). Took an hour to build the tool (after getting a referral to a welder from a guy at our local hardware store), and about 3 minutes to get the BJ out of the knuckle. Parts were $25 at the local hardware. Hack sawed off the top of a Sub lug nut, didn't realize it didn't thread on to the rod (fine thread rather than coarse, duh) but you need the fine thread to get it on the ball joint stud. Subaru engineer who designed it this way should be shot, but he's generated a million threads on a bunch of different forums all posted by DIYers who have relearned language they hadn't used since they discovered in junior high.
    BTW, you can find a good vid on Youtube by Matthew Eddy, search on Subaru ball joint. First thing he did was bust his pinch bolt, so most of the video is fixing that problem, but he builds the tool, and gets the BJ off in a jiffy. Good luck!
