DIY: Alignment, thats right align your car at home with simple tools. - Page 2
Results 16 to 30 of 35
This is a discussion on DIY: Alignment, thats right align your car at home with simple tools. within the Suspension and Handling forums, part of the Tutorials & DIY category; In for the review! Good call....
    May 2010
    Pittsburgh, PA
    In for the review!
    Good call.
    2011 STi Build Log
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Bumpdate...BUY the parts in quotes
    Quote Originally Posted by 06wrx4me View Post
    I have a feeling my ball joints and/or tie rods are on the way out. Since I have 99,9xx miles and have replaced everything else since new I ordered
    Whiteline Front Roll Center Adjustment Kit
    and an
    ALK-comfort
    Since these tires are almost shot, I might as well sort the alignment out full on them.
    Installed the RCAK and ALK this weekend. WOW game changer. I have been chasing under-steer and body roll through springs, dampers and sway bars only to have dialed out some but been left wanting. These two items made as big a difference as swapping out the suspension and adding sway bars. Pretty hard to believe for the small amount of parts that gets bolted on. Turn in is vast improved, and steering is back where it should be.
    After reading up on how the ALK and RCAK help with the roll and Dynamic Camber under suspension load, I decided to try something. I had been throwing camber at the front to help with turn in and to dial out understeer, but since these parts were supposed to cure that by themselves, I decided to dial back the front camber to -1.5 deg.
    So currently running:
    Camber
    Front -1.5
    Rear -1.3
    Toe at 0 all around.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    May 2010
    Pittsburgh, PA
    Good call on the alignment.
    I think you'll be okay around -1.5. What's your spring rate at? Are your sways pretty aggressive?
    2011 STi Build Log
  6. #19
    Jun 2006
    Nor Cal
    Springs = RCE blacks
    Sways= Perrin 22mm
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  7. #20
    May 2010
    Pittsburgh, PA
    Sways= Perrin 22mm
    I'm not familiar with the Blacks or sway bar sizes for your chasis, but I'd assume its similar to my set up with RCE blacks & RCE sways on the newer chasis. I think I'd aim for -2 degrees as far as camber goes, personally. I guess see how 1.5 feels and go from there. Never know.
    Our cars, even with the mods you just put on, just don't have "nice" dynamic suspension characteristics. AWD cars are missing most of the 'features' that traditionally give RWD cars that dynamic camber as they go through the turn. Those mods are a good start though, no doubt.
    Look into specC top hats by chance? They'd be a great complement to the setup.
    2011 STi Build Log
  8. #21
    Jun 2006
    Nor Cal
    I have Whiteline Com C top hats.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  9. #22
    May 2010
    Pittsburgh, PA
    Disregard my ignorance =P
    Good stuff. Let me know what ya end up with. I'm always interested to see people's impression of various amounts of camber in a given setup.
    2011 STi Build Log
  10. #23
    Registered User Terminal Kuz's Avatar
    Aug 2012
    SoCal
    Just bought the whiteline com-c tophats for the front. Also ordered Group N for the rear. Gonna try to go -1.5 in the front but idk how much camber i can get in the back. I want -1.0 in the rear, will i be able to achieve this without camber bolts?
    2005 WRX (Silver) SoCal Subie
    Blobeye Syndicate #1093
    http://www.clubwrx.net/forums/builds...al-05-wrx.html - Build Thread
    http://www.flickr.com/photos/34009765@N06/ - For whatever pics i take.
    Mikie13-Spend money on hookers and blow. That's a better intake.
  11. #24
    Jun 2006
    Nor Cal
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  12. #25
    Jun 2006
    Nor Cal
    Quote Originally Posted by Terminal Kuz View Post
    No.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  13. #26
    Registered User Ampliified's Avatar
    May 2012
    Warren Twp, NJ
    Definitely wanna try this in the near future after all these pot holes get fixed
    2012 DGM WRX - Stage Two 93 - Stink Eye Mob #908
    The Epic Life of Emily the WRX
  14. #27
    Jun 2010
    Nor-Cal
    OP, caster is not "technically" adjustable, but you can get about +-0.5° of adjustment from the transverse link.
    To do this you loosen the two bolts that go into the chassis through the transverse link, then pry forward on the transverse link (to gain caster), or pull back (to decrease it). Then tighten down the bolts when set to the desired setting.
    Oh, some people mistakenly call the transverse link a ALK, when a ALK is actually a modified transverse link.
    I've been doing my own alignments for a while. Nice write up!
  15. #28
    Jun 2006
    Nor Cal
    FWIW this setup really came alive when I changed the tires to Continental Extreme Contact DW. World of difference, sadly it was short lived.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  16. #29
    Jun 2006
    Nor Cal
    Since my signature is getting full, I'll leave this here:
    DIY: Subaru Ball joint removal tool for around $18 + 1 lug nut
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  17. #30
    May 2014
    Excellent DIY alignment post.
