Results 1 to 3 of 3
This is a discussion on 2007 WRX front and Rear Swaybar install within the Suspension and Handling forums, part of the Tutorials & DIY category; I was wondering if anyone knew of any places where the front and rear swaybar + endlink install would be ...
    Registered User SubaruWRC's Avatar
    May 2007
    New Orleans
    I was wondering if anyone knew of any places where the front and rear swaybar + endlink install would be explained? I will be getting whiteline sways with kartboy endlinks. I know I saw a rear swaybar install on this forum, and he says you need to remove a wheel? Do you have to do that? Thanks in advance.
    STU 17
    Hawk-Eye Alliance #117
    WATCH THIS
    No, you shouldn't be removing any wheels. You want the car under load during install (read: use ramps vs jackstands).
    I don't know of a tutorial off-hand, but once you get under the car, it's relatively straight-forward how to install when you're looking at it.
    May 2007
    New Orleans
    Re: 2007 WRX front and Rear Swaybar install
    Also do I need some penetrating oil? And should I buy some grease for the bushings instead of using the white line grease?
    Sent from my DROIDX using Tapatalk 2
    STU 17
    WATCH THIS
