ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > STi Technical Forum > STi Transmission/Drivetrain
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 12-21-2008, 07:23 AM   #16 (permalink)
N00b Moderator mit das motion lotion
EJ257's Avatar
Quote:
Originally Posted by greatwhite822
Hi guys,
I'm new in subaru and I need some help here, I am getting some cranking noise from the DCCD in auto mode while turning.Does that means that central diff is going down and need to be replaced.
The car has 55mil but have no idea what has been done on this car becouse I bought it two month ago.
Thanks
How sharp of a turn?
__________________
2005 WRX STi (Mods | Dyno)
CNYSubarus
EJ257 is offline   Reply With Quote
Old 12-21-2008, 08:33 AM   #17 (permalink)
[QUOTE=idipskoalmint;2403225]How sharp of a turn?[/QUOTE
I can't make "U" turn because whole car is shaking .
While turning 90degree there is a squeaks(cranks) coming up from below and rear inside wheel(left turn -left rear wheel) is lightly spining .the DCCD is set in auto mode.
greatwhite822 is offline   Reply With Quote
Old 02-09-2009, 03:22 PM   #18 (permalink)
Don't use it
Always keep it in auto unless going down hill and you want 50-50 awd. Subaru made a big mistake by putting that feature in the sti. it hurts the car using it when going slow and in turning situations.
mrpad is offline   Reply With Quote
Old 02-10-2009, 06:39 AM   #19 (permalink)
Moderator
YBNormal07's Avatar
Quote:
The DCCD manual settings really weren't intended for everday driving. For snow and gravel though, it is a very useful feature. Saying "don't use it", I'm assuming you mean "use it for when it is intended"?
__________________
tEh PriUs=teH faSTah!@@!
306 AWHP/341 AWT, Stage 2
YBNormal07 is offline   Reply With Quote
Old 02-10-2009, 07:30 AM   #20 (permalink)
tarmacsti's Avatar
I have the axact same symptoms with my sti... been to the dealer a couple of times about this and they say its normal... sure as hell dont feel it, but they say all the sti's with dccd does it and they have not yet had one with any complications.
__________________
**__The Hawk-Eye Alliance__**
Member #0135
tarmacsti is offline   Reply With Quote
Old 02-12-2009, 05:14 PM   #21 (permalink)
Glick's Avatar
Send a message via AIM to Glick
Quote:
Either leave it in Auto mode, or apply the E-Brake one click while making sharp turns at low speeds.
Glick is offline   Reply With Quote
Old 02-13-2009, 11:15 AM   #22 (permalink)
viperuws's Avatar
If you throw it in open it reduces it a ton. Its all about the different wheel speeds and how the dccd forces the wheels to spin at closer speeds to each other depending on the setting. If you have it open it will allow more of a difference between wheels allowing you to turn without the tires squealing and the car hopping like a 4x4 pick up does.
I heard only 07+ have this problem with the torsen center diff but it might be all STIs. If I am making a quick U turn I pop it in open and it doesn't happen anymore. Also full lock is great for deep snow.
__________________
CGM 2006 Subaru Impreza WRX - Sold
WRB 2007 Subaru Impreza WRX STI
Hawk-Eye alliance #100.1
viperuws is offline   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Intermittent DCCD flashing + ABS indicator on start up. Digitalfiend STi Transmission/Drivetrain 11 06-08-2009 06:55 AM
DCCD - Torque Binding subwrxsti STi Transmission/Drivetrain 5 08-17-2004 03:24 PM
what is the bare minimum to get dccd to function on a us sti tranny jesse370 Transmission & AWD 7 08-10-2004 08:37 PM
Dccd Flat_four STi Technical Forum 8 10-26-2003 08:32 PM
Removing the DCCD..... UR2 SLO STi Technical Forum 4 10-08-2003 07:48 PM
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
