How much do you actually need to port?
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
This is a discussion on How much do you actually need to port? within the STi Technical Forum forums, part of the Tech & Modifying & General Repairs category; Well I was doing some thinking and my local mechanic could probably machine out however much needed on the wastegate ...
    Registered User StaticX313's Avatar
    Jul 2003
    Huntsville, AL 2004 Blue\Silver WRX STI
    Well I was doing some thinking and my local mechanic could probably machine out however much needed on the wastegate side to keep it from creeping... so I was wondering , does anyone know how much they ported it out? pics? or anything? Thanks.
    Robert~
    Also... how much better does it feel? When I floor it with just a catback its almost like you can feel it trying to overboost, I just want a solid feeling so that Im not half throttling it to make sure i dont go over. Thanks.
    That and while I had the downpipe out I was goin to have him look at it.
    Static X Motorsports, INC.
    A ChriSTIan Corporation
    Registered User Invisiguard's Avatar
    Sep 2003
    SF Bay Area
    hope this pic makes sense...
    Invisiguard@sbcglobal.net
    Sep 2003
    SF Bay Area
    compare that open pic to where the wastgate sits closed, notice the amout of area that the wastegate covers when you look at both pics. its about 1/16" of seat area left, this is a deadbolt P+P
    Registered User Daytona's Avatar
    Dec 2002
    Houston, Tx
    so I shouldn't just bust out the dremel to do this one?
    Is this extreme?
    Because I don't want to be a part of anything that's not extreme.
    Sep 2003
    SF Bay Area
    definitly worth a shot for a DIY, they basically ported the wastegate, blended the exhaust outlet right next to it, and cleaned up the inlet area a bit, if you have a dremel with a few bits that can grind on cast iron and an afternoon to spare go for it, just be sure to leave that 1/16" area for the wastegate to seat
    Registered User STiLL WILL's Avatar
    Sep 2003
    Co-founder of CCMW
    Invisiguard,
    What kind of changes have you observed after the Deadbold PnP to the VF39? Fuel cut not a problem anymore?
    Thanks,
    -STiLL
    Dec 2002
    Houston, Tx
    my idea was to mark what was to be removed with a marks-alot or possibly some wite-out if it wouldn't chip from being ground near.
    Great pics, I assume the blending you are talking about is reducing the bump between the wastegate port and the outlet? Was your inlet bumpy/full of burrs? I haven't taken mine off yet, but I assume you don't mean to increase the radius of your inlet...
    Is this extreme?
    Dec 2002
    Houston, Tx
    ok, what is a deadbolt P+P, is that a new wastegate?
    <--- n00b to moding turbos
    Is this extreme?
    Sep 2003
    SF Bay Area
    deadbolt is a company that sells upgraded turbos, they also Port and Polish tubos(p+p) the area Im talking about blending is right where the exhaust turbine outlet is right next to the wastegate, you can see in the pic how its a biy rough, thats where they radiused it a bit.
    Sep 2003
    SF Bay Area
    Originally posted by STiLL WILL
    Invisiguard,
    Thanks,
    -STiLL
    well it just got a couple days ago and its still sitting on the floor, its going in as soon as I get my DP and fab and extra pipe for this
    I'll report back how it goes
    Registered User sk1CL-S's Avatar
    Jun 2003
    Windy City
    Hey, is that a cracked near the wastegate flapper?
    01 CL Type S *Sold*
    04 Silver/Gold STi
    -COBB AP Stage 2 / 93 oct
    -Drop in K&N filter
    -Bosal Single Tip Catback
    -Helix 3" Catless Downpipe
    -Replica STi front strut tower brace
    Registered User StoplightWarrior's Avatar
    Jun 2003
    CA
    What does porting the wastegate accomplish exactly?
    Sep 2001
    Edmonds, Washington
    It improves the flow of exhaust gas through the wastegate, the actual diameter of the wastegate hole is increased, thus reducing resistance. Also flow out of the turbine is improved by removing some sharp edges around the wheel, this reduces turbulence. Hopefully, the wastegate porting will keep boost creep to a minumum. A common problem on the STi is exhaust gas flowing through the turbine rather than the wastegate at higher rpms when the wastegate is fully opened, this makes the boost pressure creep up as the turbine wheel has to spin faster.
    http://homepage.mac.com/supermarkus/PhotoAlbum1.html
    Mullet haiku:
    Daughter's BMX
    Takes me to welfare office
    Trans Am is on blocks
    Registered User g0tb00st's Avatar
    Mar 2003
    MA
    Eliminates the dreaded boost creep issue many STi owners are facing when they are running a more free flowing exhuast setup.
    Jun 2003
    CA
    is boost creep when your boost builds up and cuts out? Cant a reprogrammed computer fix that?
