STI in 4th gear at 4000rpm issue
Results 1 to 8 of 8
This is a discussion on STI in 4th gear at 4000rpm issue within the STi Technical Forum forums, part of the Tech & Modifying & General Repairs category; Hi All, I have noticed something on my new my15 sti recently and wanted to know if anyone else is ...
    Jan 2015
    Melbourne
    Hi All,
    I have noticed something on my new my15 sti recently and wanted to know if anyone else is having the same issue...
    First off my sti is in Sport Sharp mode and in 4th gear at around 2000 - 2500rpm and when i put the foot down and hit 4000rpm it gets a pretty violent kick back and i have no idea what it is. Almost like a limiter but really harsh / or a cut of fuel. Have no idea?
    Any help would be appreciated.
    Thanks! Theo
    Aug 2012
    Tucson, AZ
    There is close to no information on what's happening so it'll be near impossible to help, based off of what's provided
    Stinkeye member 520
    Jan 2015
    Melbourne
    What else are you after?
    Thats half the problem is that its almost occurring for no reason... No warning lights, no smells, nothing...
    If i could give more detail i would.
    Was hoping someone else may have had this issue and knew what was causing it.
  5. #4
    The ECU can cut fuel in an overboost situation. Take it to a dealer...
    Resident Tuner @ WTF Tuning
  6. #5
    Aug 2012
    Tucson, AZ
    Most times when the ecu cuts boost from an over boost it throws the range a performance code as well. We also don't know what mods you have, when the issue started (after installing something or doing some bit of work, etc )
    If anything you have a warranty. Use it
    Stinkeye member 520
  7. #6
    Quote Originally Posted by nsibanez
    Not always...
    There is a separate fuel cut and DTC trigger value. It depends on the way the map is setup.
  8. #7
    Jan 2015
    Melbourne
    Car is stock (no mods)... I will visit the dealer during the week and let you guys know what the outcome is.
  9. #8
    Aug 2012
    Tucson, AZ
    Not always...
    Just speaking out of experience. On the stock map in dead middle of summer in CT (decent humidity and anywhere from 80s to 90s) I'd hit it every now and then (also before my inlet tore) and every time I threw the code. Also only happened in 4th mid range
    Stinkeye member 520
