Ecu wiring question
Results 1 to 2 of 2
This is a discussion on Ecu wiring question within the STi Technical Forum forums, part of the Tech & Modifying & General Repairs category; Hey so my 98 forester sti ej20t swap has a issue its getting no spark the coil is fine what ...
    Oct 2014
    Ecu wiring question
    Hey so my 98 forester sti ej20t swap has a issue its getting no spark the coil is fine what I need to know is which wire from ecu send the signal to the igniter. I need to see if its sending a signal.
    Oct 2014
    Ok so figured some stuff out I have the 3 wires to ignition coil so when I test the inputs unplugged its 12v for 1 wire and between 1-3 for the other 2 wires which is expected but when I plug it in to coil all 3 wires read 12v is that a short and yet no spark emmits from coil at all. Please guys I need help
