Boost Gauge Reading Vacuum..
Results 1 to 14 of 14
This is a discussion on Boost Gauge Reading Vacuum.. within the STi Technical Forum forums, part of the Tech & Modifying & General Repairs category; Hey guys I'm new here, and I'm sure this has been covered multiple times, but I can't seem to find ...
    Jan 2014
    Hey guys I'm new here, and I'm sure this has been covered multiple times, but I can't seem to find any info on why. I've connected the boost guage Tee just like I've seen on other forums, to the hose coming off of the OEM BOV, and ran my tubing back to the guage, I do hear a little bit of a leak around the gauge, is this normal? And why is it reading vacuum pressure and not boost pressure where I've connected it? Thanks guys
    Jul 2012
    Rocky Top
    At idle and during most driving the system is in vacuum. You will only read positive atmosphere when you're turbo is spooled and compressing the air.
    Quote Originally Posted by GODSTILLA View Post
    No. Fix the leak.
    Because the manifold is under vacuum, not boost, at those times. You should see it go past atmospheric pressure (or "zero") and into boost though if you have enough spool.
    Sep 2012
    You also shouldn't hear anything around the gauge, sounds like there could be a leak.
    *edit*
    SD_GR beat me to it.
    Jul 2011
    Hunterdon County
    You shouldn't be getting any sort of leak around the gauge. You are going to want to find the source/patch that baby up. You're readings are going to be of with a leak in the system.
    You should be reading vacuum at idle/deceleration/some cruise situations. Pretty much anytime there isn't a load on the engine you are going to read vacuum.
    When you put a load on the engine such as accelerating or driving up a hill you will start reading boost in the positive numbers.
    Jan 2014
    Ok. I'll go Ahead and put a clamp on the guage, now what's happening is that It'll read 10 Vacuum and then when I give it gas it'll just go to 0, It wont go any higher even at WOT. I just want to make sure that the place on the BOV the small hose, is the correct place to Tee it off at? Hopefully when I clamp down that hose it should fix it but I'm starting to have my doubts given that It wont go above 0. lol
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    What year car are we talking? With that someone will be able to give you the right info as to where to t-in.
    Jan 2014
    haha Sorry I guess that would be some important info, it's an 06 STI, I attached it right at the BOV, where there was the small guage vacuum line
    Jan 2014
    OK, I think I figured out the problem, As I was making a video to show all of you I saw that my T had broken in half, so Immediately went to the auto parts stor got a new T and a new Vacuum line. I have it installed now and the guage reads 20 Vacuum and then when I go WOT it shows 10 pounds, just wanted to make sure this all sounds correct? I was under the impression I should be running about 13-14 lbs?
    Max boost will differ according to gear and load, but in general you aren't wrong; your max boost should be a bit higher, yes.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    What does the gauge read when the engine is off? What altitude are you at? Is it mechanical or electronic (the sensor, not the display). Does it have a calibrate option?
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Jul 2012
    Rocky Top
    Side note, why do some boost gauges read slightly less than zero when the engine is shut off? build quality of the guage, Boyle's law phenomena..lol
    Jan 2014
    Guage reads 0, it's a little below the Middle of the "0 range" but it reads 0 when motors off. Im about 2000 above sea level, mechanical, it's kind of a cheapy one from oreilly's it was $30, No Calibration option. Now I guess it could be the guage being that it was only 30 bucks, now I'm planning on replacing it with one of the prosport Evo Gauges, have you guys had any luck or reviews on them? Here's a link to them
    Prosport Gauges Evo series gauges, EVO Red and Blue digital gauges
    Jul 2012
    Rocky Top
    I don't like prosport and I've owned them, mechanical and electrical. The mechanical gauges are ok and they do the job, but neither type was very accurate. Due to the way they are wired I couldn't dim them and they were much too bright for me. They're just basic and about worth the price. Not garbage, but not great either. I would just hold on to the money and get something a little better.
    *Opinion, grain of salt.
