06' STi won't run and just died on me ; ( please help
Results 1 to 15 of 15
This is a discussion on 06' STi won't run and just died on me ; ( please help within the STi Technical Forum forums, part of the Tech & Modifying & General Repairs category; Ok, so i wake up to take my 2006 STi to get detailed and i figured i'd have some fun ...
    Dec 2013
    Ok, so i wake up to take my 2006 STi to get detailed and i figured i'd have some fun on the way. Yesterday i checked the oil, added a 1/4 qt, and i was between 1/4 tank and 1/2 and i thought to myself....."I never let the fuel get that low but ill just fill it up tomorrow after the detail job"
    So i started the car, let it idle and warm up and started my commute and there is a nice straight stretch so i figured id hammer down since nobody was around, i proceeded to hit 85mph and was shifting rather high, 5k RPM, and once i hit fifth gear it just pretty much shut off on me....
    i had power, just no motor, does that make sense? so i coasted to a safe location, pulled off and turned the key to the off position.
    I then tried to start the car, which took 20-30 seconds roughly, at this time once it finally fired back up it idled a little rougher than usual and when i would give it a little bit of throttle it owuldnt instantly start cutting out but would still idle.
    So i put it in gear and tried to drive it to my maintenance guys house, at this point i put it in gear and tried to drive but as soon as you let off of the clutch and give it anyt throttle it cuts out and misses even more than when it is in neutral.
    ANY IDEAS?
    Fuel pump? jumped timing? timing belt? did i blow it up? Water in gas tank????
    please any input at all is helpful
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Got a check engine light (aka CEL)?
    Dec 2013
    no CEL, sorry forgot to mention that
    everything is as its supposed to be gauge/light wise
  5. #4
    Registered User Formula156's Avatar
    Jan 2013
    Orlando
    Did you check your radiator see if there is any oil in the fluid? When you started the car up did you smell of antifreeze? was there any white smoke coming from your exausth?
  6. #5
    Dec 2013
    No smoke and all fluids good
    The cruise light flashes occasionally? The boots are good on my TMIC
  7. #6
    Dec 2013
    Guys I'm desperate. This shop is trying to screw me. TPG tuning, 4 hours away, told me the doubt it jumped time and this shop insists that's what happened. They aren't that knowledgable.
    Fuel filter? PLEASE ANY HELP?! I'm desperate here
  8. #7
    Dec 2013
    The shop now says there is no fuel pressure.
    Any recommendations on a fuel pump? Pen? Walbro? If I get aftermarket will I have to retune??
  9. #8
    Dec 2013
    Oem is $400
  10. #9
    Registered User SilverSemoWrx's Avatar
    Oct 2013
    Jackson Missouri
    It could be a fuel filter or fuel pump. My dad had a ford Taurus kind of do this one time. He drove 3 hours and when he was almost home he lost all power and it died a couple blocks from home. We just banged on the fuel filter and it would start. That car had a bunch of problems though.
    ~2004 Subaru Wrx - Stage 2
    ~2013 Honda Civic
    -I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming.
    -Nobody remembers the guy who finished second but the guy who finished second.
    -Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.
  11. #10
    Dec 2013
    My guess at this point is fuel filter or pump.
    If it's a fuel pump I'm hoping I can buy an aftermarket pump and not have to re tune it because an Oem pump $400 and aftermarket is $150
  12. #11
    Oct 2013
    Jackson Missouri
    Buy a wallbro. That's a good brand. I thinks it's like a 255? And if I remember right you shouldn't have to tune because your motor will only take what it needs.
    ~2013 Honda Civic
  13. #12
    Dec 2013
    Okk thank you!
  14. #13
    Palmyra, NJ
    A Walbro would be fine. You won't need a retune just with a pump.
  15. #14
    Dec 2013
    The fuel filter blew apart? So I'm replacing both pump and filter. Any ideas on what caused this?
  16. #15
    Palmyra, NJ
    Quote Originally Posted by Rmccabe91 View Post
    Probably clogged. Put pressure into anything to where the medium being pumped can't pass through, it's bound to pop.
