This is a discussion on Boost creep / fuel cut within the STi Technical Forum forums, part of the Tech & Modifying & General Repairs category; Originally Posted by jorgee17 So basically i have a 2007 subaru wrx with a full turbo back exhaust a new ...
So, this **** just happened to me on my way home, i hate fuel cuts it pisses me off. This is the second time its happened. WTF!?!?
I am having problems with compressor surge not sure whats going on its a stock turbo
I think I had my first boost creep expereince. I have a 03 WRX with a APEXi catback exhaust. I was running at high RPMs in 3rd, changing gears when the car kinda lurched and jerked. It scared me, I thought I blew my engine or crushed my tranny. I read that with the 2.0 boostcreep wasn't a big issue, but that's what happened. I read the code that came up, it was the "Turbo/Sup wastegate solonoid A range performance" so I'm guessing it was the boostcreep. Anything else that can cause this? I have a boostguage installed, sometimes it spikes pretty high (it says 18) when I accelerate, is this normal?
Thanks!
if you know where your boost controll selenoid is im almost positive one of the lines are loose or off because i had this happen to me to
Can boost creep happen to a stock car?
Just want to add to this for anyone out there planning on going stage2 or higher. Do not go catless with your down pipe or turbo back exhaust unless you plan on upgrading your turbo, fuel system, and intercooler at the same time. going catless at stage2 or lower will result in major boost creep and boost spikes up to 22.3 (sensor max) and higher.(completely over working the turbo!) I know this from experiance with my 08 STI. I think if you plan on going above stage2, you should build the entire motor or buy a built motor anyway.... but thats just my opinion. If you want to see an example check out my protune results in Electronic Tuning. 311 WHP 329 WTQ, it tapers off at 5k instead of 6k+ which will be fixed when I get my down pipe catted. We had to cut most of the boost early to prevent it from creeping to 20+ after 5k. Once the down pipe is catted we should be able to keep the Boost and WHP flat accross the chart to about 6k.
MODS
AMR turbo Back Exhaust
K&N Typhoon
Cobb AP2.0
Protune Stage2 Map
old thread but i recently bought a wrx, yesterday to be exact and today on the highway i experienced this FUEL CUT u all speak of, being noobie to rubies, but a former clubrsx member i knew that the forums were my first go to place for info, i found this thread and it all make sense, i have a cobb DP and exhaust/ muffler whatever u call it, it says that an external waste gate should do the trick so would this fix it? 38mm External Waste Gate Blow Off Valve BOV Adapter Kit Pipe Coupler Clamps | eBay
Knowing forums are a good place to get answers to issues is a great first step. Knowing eBay isn't where you should be shopping for parts is anotherOriginally Posted by illerikill
That will not work with our cars. You need a flange for the EWG off the uppipe. That said, I don't think that's really necessary, in this case. It's likely you simply overboosted an amount to trigger the DTC. What's done to the car?
Is it a 2.5L model? It may just not be tuned - I'd confirm that first as it is critical for other reasons as well.
