Page 6 of 10 FirstFirst 12345678910 LastLast
Results 76 to 90 of 141
This is a discussion on Boost creep / fuel cut within the STi Technical Forum forums, part of the Tech & Modifying & General Repairs category; Originally Posted by testes1010 an EWG is mounted pre turbo to a EWG Uppipe. Yes, an EWG will fix boost ...
  1. #76
    Registered User orvtech's Avatar
    Nov 2005
    Miami
    Quote Originally Posted by testes1010 View Post
    an EWG is mounted pre turbo to a EWG Uppipe. Yes, an EWG will fix boost creep but I'd highly highly highly recommend a retune for the most & safest benefits.
    ok, so to do things right, would be EWG + Up pipe for EWG + dump pipe + plust ECUTEK or UTEK.
    right ?
    how ever the economical way would be sell my catless DP get a catted and wait for Cobb to release the 2007 STI AP.
    as a third way here is a question, cant i go with a manual boost controller + sensor bung without out EM ? utill cobb releases the AP. >
  2. #77
    Feb 2004
    Evansville, IN
    Quote Originally Posted by orvtech View Post
    boost creep is a mechanical wastegate issue, a MBC will not help.
    Wait for CobbAP or Enginuity/ECUFlash...however comes first & is cheaper
    1988 Celica Alltrac
    Hallman Pro, 15x7.5 +20mm Rota Slipstreams
    2005 LGT 315whp/340wtq@21psi - Sold
    VF52, Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, ROMRaider
    2003 WRX 371whp/355wtq@24psi - Sold
    TD05H-20G-38mm Tial, Meth Injection, Hyperflow TMIC, ROMRaider
    Dyno Chart METH vs 93 oct
  3. #78
    Nov 2005
    Miami
    Ohh, i though that by regulating the boost you could mitigate the boost creep.
    dude ... i want soooooo bad to get to stage 2.
  4. #79
    Feb 2004
    Evansville, IN
    nope, you'll still creep because the wastegate can't get enought exhaust out the wastegate hole.
    1988 Celica Alltrac
  5. #80
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    right ?
    If you still have your stock cat back, just connect that up to your catless DP and that should provide you with enough backpressure to avoid boost creep. I've spoken to 2 other members who have done the same successfully with an STi. You won't really notice the HP difference between the stock catback and larger catback.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  6. #81
    Nov 2005
    Miami
    Quote Originally Posted by YBNormal07 View Post
    but i love my HKS Ti
  7. #82
    Jul 2003
    PA
    I guarantee you'll like stage 2 better than a louder exhaust. Besides, you can always put it back on once you've sourced a catted DP.
  8. #83
    Nov 2005
    Miami
    i think the best way to go here is as you said on your first post. get a catted DP, i will sell my Invidia DP and try to get a helyx catted.
  9. #84
    Registered User xourheartsdesir's Avatar
    Mar 2007
    Milford, CT
    just got new 04 sti with mods from dealer....but a problem now...
    its a 04 sti with a 3 1/2 inch turbo back with custom port and polish intake manifold and aem cold air. it pulls like a motherrr but when im at full throttle on the highway going about 110 it stops at like maybe 5000rpm...is that a fuel cut? i can go faster without giving full throttle just when i get on it it does. bigger injectors? or the wastegate thing? i hardly have a clue whats done to this car i just took it today from the dealer. sucks buying a used without knowing what is done. please help me outttt
  10. #85
    Feb 2004
    Evansville, IN
    Quote Originally Posted by xourheartsdesir View Post
    fuel cut due to over boost. You need EM Tuning...
    1988 Celica Alltrac
  11. #86
    Mar 2007
    Milford, CT
    the dealer said that the kid got its intake and exhaust all done and installed and dynoed professionally.....why would it be like this now? how do i turn it down if thats the case...i dont want to **** anything up...speicially if it was tuneddd
  12. #87
    Feb 2004
    Evansville, IN
    since you don't know anything about the car take it to a Suby-specialty shop(NOT THE DEALER) to have a look over.
    1988 Celica Alltrac
  13. #88
    Registered User TheReaper's Avatar
    Jun 2004
    Vista, CA
    Even when tuned properly a lot of people still get fuel cut from over boosting, I still get fuel cut in 5th and 6th and sometimes even 4th and 3rd will have cut when Im at wot (it only happens in 3rd and 4th when its extremely cold outside). I have an 04 STi with short ram, catless tbe, and utec pro tuned. I pull very hard from 1st through 4th with no problems most of the time but 5th and 6th are almost useless in a race unless it is warm outside (for some reason I dont get fuel cut when its warm, 80+ degrees). but like xour said you can get to the higher speeds by going maybe like 50-75% throttle and you wont get knock then but as soon as you go past that 75% area you'll be guaranteed to get it and that is why I rarely ever hit 5th or 6th wot. Only solution for people in our situation is to do an external wastegate but I'm gonna just waste till I upgrade the turbo and everything else, until then I'm rarely going to hit 5th or 6th hard, thats the only solution.
    Oh and even when you think your running good or you reduce throttle to avoid the fuel cut sometimes your still getting knock, if you see the check engine light blinking thats a no no. I ran my car hard with what seemed like no problems and then noticed the check engine light would blink every so often so I basically drive like a grandma 99% of the time and bump the map to one that has not so advanced timing.
    You might be a king or a little street sweeper but sooner or later you'll dance with the reaper.
  14. #89
    Mar 2007
    Milford, CT
    i talked to him for like 2 minutes and i asked him why there was a fuel cut and he said he took the computer out or something like that...so...........something like utec? where do i buy those ive seen online for like $1100.
  15. #90
    Mar 2007
    Would bolting up just a cat-back exhaust cause boost creep? How about a cat-back with a high flow cat? Iv read through all this and its alot of info so sorry if its been posted. Also is the Cobb stage 2 accessport specifically tuned for their TBE or can you run that with your own choice in cat-back/TBE without getting boost creep. Thanks for your help.
