Boost creep / fuel cut - Page 10
Page 10 of 10 FirstFirst 12345678910
Results 136 to 150 of 150
This is a discussion on Boost creep / fuel cut within the STi Technical Forum forums, part of the Tech & Modifying & General Repairs category; Originally Posted by EJ257 Knowing forums are a good place to get answers to issues is a great first step. ...
  1. #136
    Feb 2013
    Knowing forums are a good place to get answers to issues is a great first step. Knowing eBay isn't where you should be shopping for parts is another
    That will not work with our cars. You need a flange for the EWG off the uppipe. That said, I don't think that's really necessary, in this case. It's likely you simply overboosted an amount to trigger the DTC. What's done to the car?
    cobb dp and exhaust with no cat, stock ecu
  3. #137
    Quote Originally Posted by illerikill
    No tune? That would explain why you're triggering the overboost DTC...
    Resident Tuner @ WTF Tuning
  4. #138
    Feb 2013
    can u tune with a stock ecu?
  6. #139
    Yes. What car do you have?
  7. #140
    Feb 2013
    2002 wrx
  8. #141
    Oct 2005
    Late Devonian
    2.0l - you DO NOT have mechanical boost creep as indicated in this topic. You should be able to run a DP with no tune. There is something else going on.
    You should start a thread and give all the details and we'll sort this out for you.
    You are looking for things like a vac. leak between the compressor and the waste gate actuator, overtightened WGA, etc.
  9. #142
    Registered User SubiesaurusWRX's Avatar
    Sep 2013
    Colonia
    I had this question posted in another post, but, it could get better answered here. Ive experienced boost creep several times since the cold weather has come in. Im running a 38mm ewg already with a grimmspeed ebcs to assist in maintaining boost. The system has been protuned for all my mods accordingly but recently i overboosted and got fuel cut. Cel code p0244 came on, but, was cleared and car was reflashed. Target boost is 18.5 psi and ive been hitting anywhere from 19.3-19.8 psi more recently. Car runs good now but i dont need this to be a reoccuring thing everytime i wanna have alittle fun. What can i do to avoid creep/overboost and fuel cut.
    2011 WRB WRX: DW 850 cc injectors. FMS tmic. Custom SRI. GT spec header. Maddad Turboback. Tial mv-s ewg. Perrin Recirc Valve. Grimmspeed ebcs, crank pulley, and up-pipe. Cobb AP w/ custom tune. ACT HD clutch w/ lightweight flywheel. StopTech Club Kit ( front). Whiteline 3-pt adj. sway bars f/r. Perrin front endlinks. Drag DR31 wheels 18x9 +15 offset. Nitto NeoGENS UHP all-seasons. Ultra Racing Rear Strut Bar.
  10. #143
    Oct 2005
    Late Devonian
    Quote Originally Posted by SubiesaurusWRX View Post
    Fortunately, you do not have 'mechanical" boost creep. You simply need to have your map looked at and tweaked to solve the problem. Wastegate duty cycles and all that - they just touch up your boost control or temp. compensation and it should work out great. Tuners can't necessarily predict what will happen in the cold with a particular car. I'd think about maybe saving the map version you have and using it just in the summer as well (unless they can handle it with just temp. compensation which will reverse itself when it warms back up).
    To "avoid" it shift more often - don't start from low RPM in a tall gear (e.g. 4th-5th) and pull it all the way to the top. Us up the top end of 3rd first so you start higher in 4th....
  11. #144
    Registered User drumbeat's Avatar
    Aug 2014
    my 02 recently had the same issue as mycologist but mine is tapped on my gauge keep getting the code if I don't feather the throttle and manually force boost to drop
  12. #145
    Oct 2005
    Late Devonian
    Quote Originally Posted by drumbeat View Post
    I haven't ever actually had an issue, just FYI. You do not have uncurable mechanical boost creep. with a 2.l because it doesn't ever happen. Make sure you have all of the vacuum lines installed correctly WITH NO LEAKS. Leaks will allow pressure to bleed off before it hits the wastegate actuator, which will cause the wastegate to stay closed, causing boost to spike uncontrollably. This thread deals with the topic when all is right and it still happens.
    Technical Articles
  13. #146
    Aug 2014
    hmm my setup looks way different than that....
  14. #147
    Aug 2013
    Phoenix Arizona
    Hi everyone. Sorry I've read through the thread but I'm still not sure what to do in my situation. I have a 2013 WRX base. I have been running the V2 stage1 91ACN (Arizona) map for a while now. I am about to install an invidia catless downpipe (with proper adapters) and move to the stage 2 91ACN map while still running the stock CBE. Am I in danger of experiencing mechanical boost creep?
    Eventually I plan to get a protune done, but I am still a bit new and am not sure this can help with mechanical boost creep.
    Sorry to revive such an old thread.
  15. #148
    Aug 2012
    Tucson, AZ
    Quote Originally Posted by Cenpho View Post
    Yes you are and it cannot be tuned out by a protune. An ewg solves the issue
    However there's a newer version of catless pipes that don't seem to show these issues
    Stinkeye member 520
  16. #149
    Registered User STIL3TTO's Avatar
    Mar 2015
    Firestone, CO
    Thank you! This is very helpful. I am having similar issues with my STI. I have a Perrin kit and will have to probably fabricate a heat shield, but I look forward to trying it!
    I keep my heels high and my cars low.
  17. #150
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    I am experiencing this symptom with my 14 Wrx EJ255. I am catless at the moment, however will be reinstalling my 3" cat till I get an EWG setup.
    Ive got my eye on the Grimmspeed EWG up pipe with 38mm waste gate and an electronic boost controller by COBB or Grimmspeed. I will of course get a protune to work with the AP.
    14 sedan: Protune: 318AWHP 344ft lbs up pipe, Tial EWG, AEM intake, Cobb AP V3, 3" TBE, Avo FMIC, Turbo Smart bpv, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop. Eibach sways, Perrin Spherical end links, Cusco subframe brace, White Line sway braces, Perrin sub frame bushings.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
