Too big is almost as bad as too small (assuming a good tune is applied to the car). I think you'll do fine with 650s. I saw dyno charts at NASIOC where the 18G was tuned to high power levels with pinks.
This is a discussion on 650 injectors ok for 18g turbo? within the STi Engine Performance forums, part of the STi Technical Forum category; im either going 18g or dans set up. the pe650 injectors will be ok for this set up or should ...
im either going 18g or dans set up. the pe650 injectors will be ok for this set up or should i go higher?
