Installed a VF34 today... - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 55
This is a discussion on Installed a VF34 today... within the STi Engine Performance forums, part of the STi Technical Forum category; Originally posted by myloSTI did you need to port your new turbo? Specificly, the wastgate......
    Registered User Master Of Pain's Avatar
    Houston
    Re: VF34 ?
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    Re: Installed a VF34 today...
    Originally posted by Invisiguard
    WRX guys use the 30/34 with our size injectors I should be just fine at stock boost levels.
    no!
    the "WRX Guys" are not running USDM injectors, they are running JDM 565 top feeds.
    the USDM injectors are only in the 440 - 480 cc range, and are side feed.
    This is why many of the VF22 guys are going static (or close to it) on the stock USDM STi injectors.
    I'd be very wary of your duty cycle at WOT with the 30/34 turbo.
    dR
    [EDIT] you installed a brand new turbo, and didn't allow any time for break in?
    Registered User Invisiguard's Avatar
    Sep 2003
    SF Bay Area
    Re: Re: Installed a VF34 today...
    Originally posted by dark_rex
    no!
    dR
    Yes, the stock injectors are no match for a vf22, the only 2 people I know of running one are getting bigger injectors for it, which to me makes using a vf22 not very worthwhile
    Im getting it dynoed tommorow to check A/F and idcs, could very well be close to max with them with the 34, we'll see.
    Also, I had to run out to Fresno the morning after I put it on, so it got about 550 mostly boost free freeway miles before I really got on it, and remmeber unlike metal sleave bearing turbos that need time to wear in with the shaft, bb turbos bearing spins freely and does not wear into the shaft
    Invisiguard@sbcglobal.net
  6. #19
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    Whoa. I didn't even stop to think about your post on I-Club, that you were installing these parts on a STI. So many people are putting VF34's on their WRX's, I was thinking it was just another VF34 equipped WRX. But after I read this thread, you get a big Thumbs Up from me.
    Are you going to have Bill tune it when you get and EMS installed?
  7. #20
    Sep 2003
    SF Bay Area
    No tuing here, this whole thing was just an experiment since I was putting on headers and inlet and gound a VF34 for cheap, if the AF looks good on the Dyno tommorow I'll keep it on until I get bored, but if it needs a SINGLE thing Im ditching it for a better turbo, VFs are not worth using bigger injectors/managment on an STI IMHO
  8. #21
    Registered User dizastical's Avatar
    Jul 2003
    Maine
    I will be unpatiently waiting for you to post your dyno numbers here ! What is the max boost you can run with the VF34 before it just starts blowing hot unusable air into the motor ? Any idea what max psi is usable on the VF22 also ? I know people claim 20-21 psi on a 2.0 but what about a 2.5 ? Thanx . Dave
    2004 STI ----- 11.66 @ 125.66 w/ 1.9 60' ----- 537HP/487TQ ----- 93 Octane/Water Injection
    WWW.F1DYNO.COM
  9. #22
    Sep 2003
    SF Bay Area
    Im sure the 34 would make solid boost out to 17psi in the midrange(though I wouldnt even risk it on stock fuel!) but so far I have gotten the it to taper boost to just under 14psi in 5th gear, this is about 2 psi better than I saw with the 39, but still if you absolutely want a turbo that will hold out boost to redline in every gear look elsewhere, even the 22 tapers to 15 at redline in 5th on the 2.5, so much for VFs
  10. #23
    Jul 2003
    Maine
    Cheep fun for now though ! Now I have all the supporting mods for any bolt on turbo I want ......................... Now if I could just choose one ????????????
    WWW.F1DYNO.COM
  11. #24
    Registered User STiLL WILL's Avatar
    Sep 2003
    Co-founder of CCMW
    ...will be waiting for the dyno as well as the IDC readouts!
    -Matt
  12. #25
    Jul 2003
    Maine
    Is it almost time yet ?????????????????
    WWW.F1DYNO.COM
  13. #26
    Sep 2003
    SF Bay Area
    couldnt test IDCs, they broke their logger, but it ran even more rich than with the 39! so it looks like its cool on stock fuel, but check out the spool! 200rpm FASTER than stock with headers and bigger housing!
    headers and vf39
    hp + 15.2
    tq + 31.4
  14. #27
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    Holy torque!
  15. #28
    Nov 2003
    im saving up for that turbo or vf23
  16. #29
    Sep 2003
    Co-founder of CCMW
    NORCAL,
    I suggest doing more research on the VF23, it's smaller than the VF30/34. I don't know if there's even anything to be gained with a VF23. If you go with the VF23, you might as well go with the VF28 because I believe it's a ball-bearing version of it....assuming the VF23/28 family promises gains.
    -Matt
  17. #30
    Nov 2003
    yah im reading on it now. i think im going with vf22. i got 4800 back on taxes so time to start something now lol
