http://cgi.ebay.com/ebaymotors/02-06...98778514QQrdZ1
what do you guys think about this tmic??? feed back please
This is a discussion on SoCal WRX FlatFour (F4) within the South Western States forums, part of the Regional Discussion category; Originally Posted by AspirinWhite will do... All my clamps are t-bolt clamps and the connectors are silicone I wish I ...
looks like a good deal, but I haven't heard of the brand nor see anyone attemp to install it in their subaru. Where's the bumper beam? How will the pipes route through the fender walls & under the hood? No pics of actual installation.
I'm just a skeptic because I like to use products that were engineered for the intended audience.
you still got the utec charlie? maybe i can help tune since i got that wbO2 sensor now
SOCAL F4#02 OG member
2002 PSM WRX stage 6
2007 Kawasaki Ninja ZX6R
hey i atually used that tmic its ok it does its job but it will rub on you ac line and pop a hole in it. other than that fitment is B and over all is B+
cheep and effective.
Driver: Francis-Paul Dela Cruz
04' Wrx Utec stg.3
Home: Glendora Mt. Ridge
F4 #09 <---- the the suby-guru in-training
|[ D. D. i. D. ]| <--- Support the cause!
speed density uses the gas law to figure out how much fuel to put out. the car runs way better between shifts because it no longer runs rich. the power delivery is a whole lot smoother than with the MAF setup. with the old MAF setup, the power would hit like a train and the clutch would slip really bad as where with SD the power is more smooth and is a little easier on the clutch. having the power hit like a train is pretty awsome but id rather have it smooth and not break anything
" I got four doors to fit more wh0res !!!"![]()
SOCAL F4 MEMBER "00"
(CLUBWRX'S 1ST OFFICIAL "F4" TEAM) est. May 2, 2005
