SoCal WRX FlatFour (F4) - Page 414
This is a discussion on SoCal WRX FlatFour (F4) within the South Western States forums, part of the Regional Discussion category; I know how this sounds but what kind of hp could I expect on an STI with a DB big ...
  1. #6196
    Registered User rx4mj's Avatar
    Sep 2005
    Freezing my arse off in NYC
    I know how this sounds but what kind of hp could I expect on an STI with a DB big 16g all P&P's w/ 15psi WGA and clipped wheel with all the supporting mods( TBE, turbo inlet, Spearco TMIC, inj, and Utec tuned by harman)? And which inj would be best UR 630 or 660. I already have the turbo and don't want to sell it and get something else, plus the spool would be rideculously fast
    (blarg)
    Hey guys, I'm back!!!
  3. #6197
    Mar 2002
    Calmer than you are
    I wouldn't do a wheel clip on a 16g. I also wouldn't get the 15 PSI WG...that's too high for what we're running...you may not be running much more than 15 PSI of boost at the top, so not being able to control boost below 15 PSI is just nuts.
    as for injectors, 600's will be fine. more than that is overkill.
    wheel clip gives up low end to give you more at the top...the whole point of a 16g is to spool up quick, so why would you get one, and then reduce the very thing that the 16g excells in?
    if you want more top end, then get an 18g...clipping a 16g is pointless.
    I don't think the displacement of the motor matters when calculating HP since that's done by airflow, and how much fuel you can burn given the maximum amount of air the turbo can deliver...the Deadbolt Monster 16g is supposed to top out at ~375 HP at the crank...we'll see how close I get to that in a few weeks...looks like Gruppe-S will be doing my tune...the tuner is a Rim this weekend so I will talk to him more on Saturday.
    -edit-
    just re-read and see you have the BIG 16g - I still wouldn't clip it, but you're looking at performance near VF22 levels...VF22's run just fine on STi pinks and 600's should be plenty...you're probably looking at ~400 HP at the crank with all the proper supporting mods.
    go f*** yourself
  4. #6198
    Sep 2005
    Yeah I wouldn't clip it either, but that's the way it came (got a good deal from someone that needed cash) it is still new. I figured that the higher displacement and the variable valve control timing might help make up for the difference in spooling time. I don't want crazy power just a little more performance than the STI comes stock. I am thoroughly confident my set up will make me more than happy. It should push me to the 300whp mark hopefully.
    **Re-edit my post: it does not have the 15psi wastegate, but WAS thinking about getting it, but no longer oh wise one
  6. #6199
    Mar 2002
    Calmer than you are
    Quote Originally Posted by rx4mj
    Yeah I wouldn't clip it either, but that's the way it came (got a good deal from someone that needed cash) it is still new. I figured that the higher displacement might help make up for the difference in spooling. I don't want crazy power just a little more performance than the STI comes stock. I am thoroughly confident my set up will make me more than happy. It should push me to the 300whp mark hopefully.
    15 PSI WG is for applications where you want to boost like 25-30 PSI
    go f*** yourself
  7. #6200
    Registered User life's Avatar
    Nov 2005
    Ontario, CA
    hey guys whats up havent been in for a while. the computer was gone for a while how's everyone been?
  8. #6201
    Sep 2005
    Hey man thanks for all the advice I really apreciate it. It is nice to be able to ask stupid questions without getting flamed, really bad.
  9. #6202
    Mar 2002
    Calmer than you are
    well if you miss that....there's always nazic0ck.
    go f*** yourself
  10. #6203
    Registered User volcomsoldier19's Avatar
    Mar 2005
    SoCal, Whales ******
    Quote Originally Posted by life
    i got my new turbo in recently
    oh and guys that spring mod does work...i installed a 9lb spring and it went up to 14.7 psi today, i think with an 11lb spring I'll hit my target boost of 17-18psi
    Quote Originally Posted by ansonowicz View Post
    So if I'm stuck in a rut or something, it's mostly because I made a wrong decision somewhere and I need to correct myself out of it.
  11. #6204
    Registered User Fahren's Avatar
    Nov 2005
    Garden Grove, CA
    SoCal F4 #22 Shoes
    Quote Originally Posted by Forester 2.5 XTi View Post
    If aesthetics was 1st, I wouldn't have bought a Forester!
  12. #6205
    Registered User subaru3169's Avatar
    Feb 2004
    la, ca
    hey eric.. just get an aftermarket clutch and flywheel and put 'em on at the same time.. while your tranny's gonna be out get a grouppe n tranny mount.. you'll feel the wonders of new mounts.. i'm just saying this for time/cost efficiency.. taking your tranny out is gonna take a lotta time, roughly a whole day.. so i suggest get all your crap in at once.. getting a stock one, putting it in then taking your tranny out again to put in an aftermarket one takes a lotta money too.. but if you have all your crap together, i suggest going to speed factory like morris suggested to me.. basically you're not being charged to put in your clutch/flywheel, but taking your tranny out is the problem.. so if you can, just wait
    always bored.. someone help me get out of this madness!!
  13. #6206
    Feb 2004
    la, ca
    oh ya forgot to add.. they charge 300-350 for a clutch job.. i'm sure if you have a new flywheel and mount to put in they won't charge extra cuz it only takes like 20 min or so.. that price is pretty generous compared to other shops
  14. #6207
    Mar 2005
    Quote Originally Posted by subaru3169
    +1
  15. #6208
    Mar 2002
    Calmer than you are
    well kids looks like my clutch is on its last legs....every time I half-engage the clutch, I hear a whirring noise...does it in every gear....either my throw-out bearing is going...or the spring....either way, guess I'll be getting my new clutch and flywheel sooner rather than later. bleah. wasn't looking forward to spending another $1200.
    go f*** yourself
  16. #6209
    Feb 2004
    la, ca
    Quote Originally Posted by blarg
    muahahaha i know exactly how you feel.. when i did my clutch and all that other crap in, i was thinking at the same time, "ya know, this could have paid for my whole tuition next qtr".. in any case i have no idea where to get a cheap clutch other than online if you don't mind the wait
  17. #6210
    Mar 2002
    Calmer than you are
    I-speed has a decent one that's not too expensive...I'm not sure if just a re-branded Exedy or what but...I'll see them at Rim so I'll see how long it would take to get one...I'll have to contact the speed factory, but they're usually pretty good about getting quick appointments....they do have a HUGE shop.
    http://www.crawfordperformance.com/p...s.cgi?Menu=5-1
    go f*** yourself
