SoCal WRX FlatFour (F4) - Page 214
This is a discussion on SoCal WRX FlatFour (F4) within the South Western States forums, part of the Regional Discussion category; Originally Posted by PaulSaidHi shure why not its going to cost u tho, imjust a little asian guy tring to ...
  1. #3196
    Registered User JBee's Avatar
    Nov 2005
    philippines
    Quote Originally Posted by PaulSaidHi
    shure why not its going to cost u tho, imjust a little asian guy tring to make a buck
    no problem...
    ::..Drive It Like You Stole It..::
    Be Green... Stay Catless
  3. #3197
    Registered User WRX13oy's Avatar
    Jul 2003
    SOCAL!! 91752
    so who is going tomorrow?
    SOCAL F4#02 OG member
    2002 PSM WRX stage 6
    2007 Kawasaki Ninja ZX6R
  4. #3198
    Registered User hellbilly1342's Avatar
    Dec 2005
    i'll be going after work...get off at 5.
    and what's the plan for sunday??
  6. #3199
    Registered User ansonowicz's Avatar
    Oct 2005
    LBC
    Quote Originally Posted by WRX13oy
    Sorry guys, can't make it this weekend. I'm working in San Diego right now (14hr so far) and prolly won't finish until 1am!!!
    *** EL MIRAGE UPDATE ***
    So on my way back, I stopped at El Mirage again. Luckily, the lake bed was open and I tested it out. It's as smooth as pavement out there. The ground is very firm and my all seasons gripped very well. In fact, I attempted some donuts and all I heard was screeching. It dug a small trench in the dirt but didn't feel slippery at all. Since I'm pretty respectful of the "Tread Lightly" concept, I didn't want to do anymore damage to the lake. We can do all the donuts we want just outside the shore.
    I pegged my gauge to 140+ mph and sustained it for about 6secs before I wimped out. I'm sure if we picked out a good line, we can make good use of the lakebed (Top Speed Challenge anyone?). There are some spots with water erosion (read: speed bumps), but that was closer to the edge of the lake bed.
    To get ballsy, I was going about 65mph and started to pitch the wheel around to test the traction. It slid a tad, so even with my stockers, I doubt things can get dangerous or life threatening.
    When driving at high speeds, I heard little gravel & other debris kicking up against the body. So those of you w/o mudflaps, don't worry. But if you're sporting the Rubbermaids, you can avoid turning your Rex into a dustball.
    On the way back, I was thinking about some small events we can have: Top speed challenge, drag races, slalom (need to find cones). One guy in our Xterra club had a gigantic inflatable soccer ball (8ft in diameter) and we would use our Xterras to pass it around on the beach, FUN AS HELL!
    Enough babbling
    F4.21 have root access, will travel
    :wq! 6MT20G
    Quote Originally Posted by volcomsoldier19 View Post
    long haul, the wagon will give you happiness in the times of madness...
  7. #3200
    Registered User scoobytime's Avatar
    Sep 2004
    West LA
    Quote Originally Posted by ansonowicz
    Enough babbling
    that is so freaking awsome i am soooooooo down to go there, that would be soooo much fun
    Socal WRX Club F4#3
    Quote Originally Posted by subaru3169
    hey you're the scruffy looking guy with the big turbo right? and i met you that day we went to southcoast?
  8. #3201
    Registered User life's Avatar
    Nov 2005
    Ontario, CA
    whats up guys, I just ordered a turbosmart boost controller and I was wondering if anyone knew or can help me install it?
  9. #3202
    Nov 2005
    philippines
    whats tom? i work at night....
  10. #3203
    Jul 2003
    SOCAL!! 91752
    tomorrow is that big meet at redlands. its at noon.
    we meet at ontario mills or something
    1. Chris 2
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
  11. #3204
    Dec 2005
    definately need to make a trip to El Mirage.
  12. #3205
    Dec 2005
    1. Chris 2
    2. Noel...will meet at Redlands when I get off work
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    should be there around 6:30 or so.
  13. #3206
    Registered User volcomsoldier19's Avatar
    Mar 2005
    SoCal, Whales ******
    Quote Originally Posted by life
    manual or electronic? if it's manual i can do it for you, you should of told me you wanted one, i made one and it worked well...i would have given it to you...
    i hope you have a boost gauge
    Quote Originally Posted by ansonowicz View Post
    So if I'm stuck in a rut or something, it's mostly because I made a wrong decision somewhere and I need to correct myself out of it.
  14. #3207
    Jul 2003
    SOCAL!! 91752
    i just checked my compression and i got
    cylinder 1 ~ 150
    cylinder 2 ~ 150
    cylinder 3 ~ 150
    cylinder 4 ~ 110
    the spark plug for cylinder 4 was super clean and looked new while the others (1,2,3) had the normal wear on them.
    time to start looking into getting a new block since building my current one would need lots of work. any suggestions? crawford? custom build it? im thinking of keeping it 2.0 since i would need lots of other mods to support 2.5 i.e. heads, porting etc.
  15. #3208
    Nov 2005
    Ontario, CA
    its a manual one with control in the cabin, and I have a boost gauge already. wish I wouldve known about you having one. I wouldnt have went and spend 200 bucks. but oh well.
  16. #3209
    Mar 2005
    cylinder 1 ~ 150
    cylinder 2 ~ 150
    cylinder 3 ~ 150
    cylinder 4 ~ 110
    hmm what would cause that? a bad ring....i say do a 2.2 block since it's the strongest or put the 2.0 on steroids cuz either way i'm sure you'll turn out with a nice motor and we will all
    or an omg pricey 2.6 stroker motor
  17. #3210
    Mar 2005
    hmm never done an in the cabin one
    if u want it done i can do it on the 5th of feb at our install meet
    pm me for addy
